Computers & Internet Logo
Posted on Oct 11, 2008
Drivers hi i have a web cam named as I CAM made in taiwan and i have no drivers for xp could u please help me out for this device to work properly
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
297
Points
I need a solution to find drivers to webcam Creative Model No. CT6840 Part. 1100001888
My pc camera is not operating need help
Hi, go to control panel,device manager,check there that your laptop dont have problem with it(check any yellow or red icon around the camera name)double click there make sure you see this message:
(your device is working properly)if you have this message so go get some web cam software or chat program to use it,if have error on that screen go to hp website type your model number in the search bar and download the software driver for your web cam from hp website or use windows update to update your driver software,windows need driver to identify your hardware and can use it,u can use update the driver software in the device manager,right click on the web cam device(Imaging devices) and choose update driver software,if u dont have software issues may be u have hardware problem,
kind regards
How to download or detect my webcam
1. Connect your web cam
  • Attach all power cords (e.g. laptop and/or web cam).
  • Plug your USB cam directly into your computer (do not use any external USB hubs). Turn your cam on
  • As long as your web cam and computer hardware are working, Windows should detect it!
2. Open Device Manager
  • For Vista
    => Click Control Panel. If you have Control Panel Classic View, click Device Manager
    => Click Control Panel. If you have Control Panel Home View, click System and Maintenance->Device Manager
  • For XP
    => Click Control Panel->System, then Hardware tab, then Device Manager button
3. Find your web cam in Device Manager
  • Understanding Device Names
    => Windows provides user-friendly device names to accomodate us humans. As far as Windows is concerned, the device name is simply a comment!
    => It's those cryptic Device Identification strings that really identify a device
    => Device Manager displays whatever device name it happens to find in the device driver
    ...==> If Windows finds NO device driver, your web cam may be named "Unknown" or "Other" device
    ...==> If Windows finds the WRONG device driver you may see your web cam with the WRONG device name
  • How to find your web cam
    => While your web cam is connected, look through all of Device Manager for devices with a yellow icon (probably a yellow question mark)
    => Be certain to expand the USB category to check all devices listed under it. Also, be sure to also check if category Other Devices appears in Device Manager and look under it as well
    => Your web cam will appear as a device with a yellow icon (probably a question mark)
    => Click on thumbnail to see the full sized image
  • How to verify the device you found is your web cam
    => Your web cam device will only appear in Device Manager when the web cam is powered on and connected
    => Disconnect your web cam. Verify the device you had found is no longer displayed in Device Manager
4. Find your web cam's Hardware Ids
  • In Device Manager, select your web cam device, rt click Properties. Click Details tab
  • Select Hardware Ids from the pull-down. You'll see a list of one or more Hardware Id strings
5. Search for a driver based on Hardware Id
> Update 1/26/2011: To avoid a common mistake, don't confuse the number zero with the letter "O". IDs may contain zero but NOT the letter "O"
The best driver will match the Hardware Id at the top of the list. The next best driver match will match the next Hardware Id on the list, etc
  • Start by searching for the Id at the top of the Hardware Id list
  • If only due to how different search engines work, recommend you cut USB\ from the search string
    => Example: If the Hardware Id is USB\VID_093A&PID_2468&REV_0001 search for VID_093A&PID_2468&REV_0001
  • You can start by clicking Search at the top of your TechSpot window to search TechSpot first
  • For more help on how to search for a driver using the webcam's Hardware IDs see this post
My laptop is (HP) AMD Athlon II P320 Laptop (G62-244CA). and my web cam is HP WEBCAM 101, its not working. I have checked the device manager and it says that my web cam is working properly. But when im...
go to device manager, un-install your web cam and re-install with the drivers cd of web cam, also change the port of the cam els the cam may gone
good luck
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
1helpful
A web cam was not found or is not workiing properly
1st You download Webcam Driver. Windows 7 Driver For Logitech Cam After this install the Webcam driver in the system.
Installation of Webcam Driver
  1. Go to the control panel
  2. Click on the System Icon
  3. Click on the Hardware Tab
  4. Click on the Device Manager then
  5. Select the Unknown Device or printer device where yellow Question Marks sign on it.
  6. Right click on it and uninstall it.
  7. After this go to the top of the device manager and click on scan for hardware changes.
  8. Driver installation Wizard start.
  9. Brows Your Driver from the Hard Disk and click on next.
  10. Driver will be install.
1helpful
I don't know what kind of cam I have?
  • For Vista
  • For XP
    ...==> If Windows finds NO device driver, your web cam may be named “Unknown” or "Other" device
    => Look if a device category Other Devices. Also, be certain to expand the USB category to check all devices listed under it
Web Cam Not functioning properly
You may uninstall the web cam driver from the Device Manager then restart the Computer. After restarting the Computer, please reinstall the web cam driver. You may locate the Web cam driver under the Imaging Devices category in the Device Manager. If the issue persists then you may perform System Restore to restore the system files to the time when the web cam worked normally.
My optic web cam not working,i installed it,but it not working,its on yahoo is black
please try to reinstall the drivers of the device properly
which is provided by the company on the cd named utility and device drivers.
Web cam is not working
You probably need drivers for your web cam.
2answers
Trying to install my web cam
I have windows XP professional OS and i have connected Veo Stingray web cam after installed driver its do's work,
I want sollutions if anybody can help me.
Please help me out.
Thanx
Grand Canyon Tech
Grand Canyon Tech
