Question about Dryers
How to install dryer belt for a ge model dbsr453gb3ww
I need a digram on how to put a dryer belt on the model number is dbsr453gb3ww
    Scholar:
  • 183 Answers
  • Unplug the dryer and pull it out from the wall.
  • 2
    Remove the top of the dryer by opening the door and taking out the screws along the top of the opening, then lifting the top. Remove the front of the dryer by reaching down into the opening at the top and taking out the screws holding the front in place. Move the front piece out of the way just enough so you can get to the drum inside, without disconnecting the electrical wires running from the front piece to the unit.
  • 3
    Move to the back of the dryer and remove the screws holding on the small access panel at the bottom. Remove the panel. This will give access to the two pulleys holding the thin belt that runs around the drum. With your pencil and paper, draw a diagram showing exactly how the pulleys are strung. Then slip the belt off the pulleys so it's hanging loosely on the drum.
  • 4
    Return to the front of the dry and pull the belt off the drum from the front. Put the new belt on the drum from the front, laying the ribbed side against the surface of the drum.
  • 5
    Return to the back of the dryer and restring the belt through the two pulleys, using your diagram as a guide. Use your hands to manually turn the drum at least one full turn to make sure the belt is lined up.
    Things You'll Need
    • Screwdriver with multiple bits
    • Pencil and paper
Posted on Jan 11, 2012
5 Suggested Answers
SOURCE:
  • 2337 Answers
SOURCE: ge gas dryer
Check this site for info: http://www.applianceaid.com/gas_dryer.html
Posted on Feb 21, 2008
larryyb
  • 291 Answers
SOURCE: need to know the exact
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Posted on Dec 10, 2008
ftw1952
  • 10319 Answers
SOURCE: G.E. gas dryer will not heat.
either the moister sensor is bad or the venting needs to be cleaned thoroughly. If clogged full of lint the sensor shuts down the heat until it is cleaned out
Posted on May 14, 2010
  • 4 Answers
SOURCE: Need belt diagram for GE dryer, Model No. DBSR453GB3WW
try this site it has free manuals for dryer repair, you should be able to find all you need there....
Posted on Nov 11, 2011
Nov 11, 2011 | Dryers
I need to know to route my dryer belt on my GE dbrl33ee2ww dryer as the belt slipped off and I did not see the correct path
Hi Roy, W/D here. I wrote this earlier for another person, but it works just as well twice.
You already have the diagram! (Bear with me).
Make sure that your power is off.
If you look carefully at the drum, you can see where the old belt was running.
Place your new belt in that position.
Now, place the belt over the motor pulley (It is in the same plane as the belt position on the dryer).
Pull the tensioning pulley past the belt, and ease it into place.
Roll the drum several revolutions by hand, just to get the belt tracking completely right.
Put it all back together and you're done!
Best regards, --W/D--
Feb 01, 2011 | Dryers
I need the belt digram for a 50" craftsman lawn tractor, it has two belts on the deck.. any help?
You need exact model numbers. Go to www.searspartsdirect.com
put in your model number and see parts list. Go to the right hand side of page and click on manuals.
Aug 02, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
May 13, 2010 | Dryers
General Electric dryer belt broken
Go to www.appliancepartspros.com and put in your model number. They sell new parts. Belts is around $10. Now the hard part trying to install it. This site will also give you a breakdown of the dryer and you can see how to get to the belt. GE pretty muck whole dryer has to be taken apart. Note when removing the front, hold drum in place and put something under it to hold it from falling. You will probably have to remove it anyway to get belt around it.
May 08, 2010 | Dryers
I need the part information for a new belt for this model GE dryer(DBXR463EBOWW)
The part number on a drive belt for the model you have listed is WE12M29. It can be purchased on line at pcappliancerepair.com for about $11. I hope this helps you.
Oct 28, 2009 | GE DBXR463EBWW Electric Dryer
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Want to make sure the dryer belt is put on right
Your issue is as follows;
"want to make sure the dryer belt is put on right"
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
This link shows belt routing for most makes and models.
Note: you may need to enter your model number to locate your particular models belt routing diagram.
http://www.repairclinic.com/0079.asp
In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 16, 2008 | GE Dryers
Broken belt
Hi , in replacing belt try to trace where belt way to go outside remove some bolts be sure unplug power , in putting back belt is the same way go in to install belt.
Feb 21, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
122 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
