SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
SOURCE: konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
SOURCE: Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
SOURCE: paper jam
Clearing Media misfeeds
To avoid damage, always remove misfed media gently, without tearing it. Any pieces of media left in the printer, whether large or small, can obstruct the media path and cause further misfeeds. Do not reload media that has misfed.
Note
The image is not fixed on the media before the fusing process. If you touch the printed surface, the toner may stick to your hands, so be careful not to touch the print face when removing the misfed media. Make sure not to spill any toner inside the printer.
Clearing Procedures
1. Pull the lever, and then open the top cover. If there is paper in the output tray, remove it, and then fold up the output tray before opening the top cover. Do not touch the transfer belt.
2. Slowly pull out the drum cartridge. removed drum cartridge on top of the printer keep it close and insure it is safe and stable where it sits. Be sure to keep the drum cartridge horizontal and place it where it will not become dirty.
Do not leave the drum cartridge removed for more than 15 minutes, and do not place the removed drum cartridge in a location where it would be exposed to direct light (such as sunlight).
3. Remove any misfed media.
4. Reinstall the drum cartridge
5. Carefully close the top cover
I hope this helps you and thanks for your question.
I the problem persists let Fixya know and we can detail a few items to check in order to determine the cause of the frequent misfeeds.....thanks........Whytfang
