KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
Posted on Jan 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My wife has a K5A mixer from the '70's that she loves. While I was checking the brushes, I over-tightened the brush cap and broke the threaded part it screws into. Can I get a new part?
  • Slo Mover Jan 26, 2013
    Didn't read enogh or pay attention the first time I replied to your problem, the threaded part that the cap screws into is also the same part made today for the K5 or K45 series mixers but it will require a complete tear down to replace. You have to take the motor out to put in new brush holders in. You will need a K5SS parts list for your mixer it will show you the position of the holders, it is not identical in parts as the manual you will look at is SS or solid state but the position of the brush holder is identical as is the part.
Slo Mover
Level 2:
Novelist:
  • KitchenAid Expert 185 Answers
  • Posted on Jan 26, 2013
Slo Mover
KitchenAid Expert
Level 2:
Novelist:
Answers
185
Questions
Helped
126528
Points
281
The Brush holder caps / covers for the K5 series whether Hobart or Kitchenaid by Whirlpool (after 1986 when Whirlpool bought Kitchenaid from Hobart) will fit the K5-A they just wont be flush like the older Hobart caps. They come in black or white.
Richard Nelson
Level 1:
Habit-Forming:
New Friend:
  • Contributor 24 Answers
  • Posted on Aug 29, 2014
Richard Nelson
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
24
Questions
0
Helped
19045
Points
47
New brush holders and brushes are available at www.nelsonezy.com as well as many other parts!
5 Related Answers
Anonymous
  • 130 Answers
  • Posted on Apr 18, 2010
SOURCE: trying to replace carbon brushes on Kitchenaid
Check the brushes. They get caked up with burned flour. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Clean the curved surface of the carbon brushes with a sharp knife being careful not to scratch the curved surface. If you have them installed wrong they will not go all the way in and will not contact the armature and it will not run. Measure the length, as done above, of the spring to make sure it is in correctly!! If it is not in correctly the spring will stick out 1/4 inch longer than it should.
Keep turning the brush until you have the shortest amount of spring sticking out when you press it in all the way then slowly release pressure on the end of the spring. You will know when it is in correctly since the difference in length is noticable. The curvature on the front of the brush must line up with the curved surface of the armature which runs from the front of the mixer to the rear.
Anonymous
  • 130 Answers
  • Posted on Apr 21, 2010
SOURCE: seating the brushes on the Kitchenaid ksm90 mixer
You don't need to seat the brushes. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Anonymous
  • Posted on Apr 07, 2008
SOURCE: kitchenaid mixer k45ss slow gear
If you look into the brush holder you will see a stopper at the botom ,(this is so when brushes are wore the spring is not driven into armature) .. the brushes have to be inserted so the groove is lined up , try that
Anonymous
  • Posted on Mar 21, 2009
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. [email protected]. Let me know if it works.
Anonymous
  • 135 Answers
  • Posted on Apr 04, 2009
SOURCE: KitchenAid KSM5PSGR Stand Mixer - attachments not turning
Hi Gail. Kitchenaid no longer has a Parts List for your model. This means that they consider it obsolete. Do an Internet search for parts. You may get lucky. Good luck!
If this solution has assisted you, please rate it. ricardok45
Sparking under the speed control switch on kitchenaid mixer
Worn carbon motor brushes typically cause motor sparking when you're running the mixer. Unplug the stand mixer and examine the motor brushes for wear. To remove a motor brush, use a screwdriver to unscrew the motor brush cap. Pull the cap and the carbon brush out.
Thank you for using Fixya.
2answers
My KitchenAid Artisan mixer started hesitating on Speed 10 like it's going really fast and then it slows down for 1-2 sec and then goes back to really fast. I was making whipping cream when it happen
Unplug it and check the carbon brushes under the black screw caps on the sides. BE CAREFUL they only fit properly one way so take note of where the chamfered corner goes. Next check for loose or broken wires under back cover. After that it's going to get tricky.
Mixer wont start
Check for broken wire under back cover. Check operation of switch contacts on black speed control plate. Check carbon brushed under black screw caps on the sides. The brushes are keyed, they only work one way.
Ksm75wh mixer stopped running
Check carbon brushes under the black caps on the motor sides. They only go in ONE way so take care, there is a blocker in the square hole on one corner. Line it up with the missing brush corner. If it's not the brushes remove the back cover & check for broken wires. Do your checking with power unplugged.
1helpful
Repllacing brushes on a Kitchen Aid Mixer K5A
Hi WEBERPENTWAT, Happy New Year! I hate it when that happens! It appears that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly on the commutators.
I'd suggest removing them again and make sure the concave contact face of the brush is resting completely on the armature’s commutators. If you've turned it 90 degrees too much, it wont' seat properly and the motor doesn’t get any juice.
See the illustration below:
I am unable to post the illustration and apologize for that inability. FIXYA.com has had a glitch in it's WebApp since 28 Dec and is not able to upload images using its own tools...duh? I have notified FIXYA.com of this problem.
Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Jan 02, 2010 • Food Mixers
2answers
The capacitor on the speed switch is burning out.
I have found that the capacitor is no longer available, along with
any of the motor parts. Armature, brushes, motor end bearing, etc, are not available.
My wife droped her kitchen aid mixer RRD150 now it wont come on. I dont see any thing broke in side.
could be motor displacement from brushes to armature
estimate cost $39.-$59.00
4-5day repair time
ship USPS it's very inexpensive
K5A refurb/repair
First thing check the carbon brushes, when they wear out they arc at the armature. Two black screw covers one either side of the top motor housing. The brushes are keyed to only go back in one way so make a note of which corner of the brush has been shaved off. If you look in the hole with a torch you can see the little blocker in one corner deep down. As a rule it's back top corner on one side and back bottom corner on the other side.
KitchenAid K45SS will not run
If you know what the brushes in the motor are then you should get some from kitchen aid or an appliance parts store. If you dont know what brushes for the motor are then find a local repair shop that will fix it for you. All the best.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
