Conector USB not comunicate, and not charge batt. I need open the case to verify flat cable conection, by I don't know hot to disassembly
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
SOURCE: device drivers for samsung yp-t9jab/xac mp3 player
Since they didn't include a specific driver, then XP is supposed to download the driver automatically. Restart your computer and try replugging the player into the computer again. Use the instructions on p. 16 of the Samsung manual for installing the software, except skip the part where it says "from CD" - just use the software you grabbed from their site. If that fails, go to the Microsoft website, and get their mtp protocol software (only if you are running Windows Media Player 11). I would guarantee you that this problem is Microsoft's fault, and not Samsung's.
-Tha Mp3 Doctor
SOURCE: my samsung yp-u4mp3 player does not connect with
plz change your USB cable ..one you using is may not be working
