SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
SOURCE: remote code
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved (remember that at times a bit of
to and fro dialogue may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: I NEED A CODE FOR A COMCAST REMOTE FOR A NEW HCT TV CAN YOU HELP?
press tv on your remote then sutup till it blinks 2 times the press 991 the tv key will blink twice.then press ch+ or ch- till the tv turns off.it will scan all remote codes once your tv turns off then press setup and the the remote will lock the code.
SOURCE: Sylvania LC320SLX tv with Cox Cable Remote--codes
hi! i have here a couple of codes for your tv, just try them, 1046, 1465. hope this helps! goodluck!!!
SOURCE: I have a HCT HD TV and need a remote control code
i used code 0134. push and hold set up button till lit then hold tv button till it flashes then put in code 0134. now push power button on remote. tv should turn off. i just had same problem. i also use a ge universal remote. hope that helps.
