Either your charger is not ok or your phone may have some problem.U should the charger which is designed for your phone.U may try wetting the pin of charger with a little much of saliva and then dry it and then connect the charger again.If it again shows bad contact of charger reconnect and if the problem persists then the phone may have a faultu jack.To check your jack connect phone to other charger if it again shows bad contact of charger then this is it your phone has got some problem
Bad contact charger
SOURCE: warning bad connection charger
charger is broken...get a new charger or charge it on pc via usb cable provided....hope it helps you guys....
SOURCE: bad contact charger
The charging port is bad, so you have to take it to a technician or get a universal or desktop charger to charge you battery.
SOURCE: warning!bad contact charger
hmm.. that usually happens to my phone.. try fixing the charger chord or chek the oulet..
Thanks for your solution, sir.
Tried your solutions.
An another mobile technician told me that when this problem occurs, he connect a zenner diode to the +ve charging tip and it helps. Is it? Should I try this? Please, advise me.
after connect with charger my SGH - T359 didn;t showing anything and now i couldn't power on my cell phone, and i found my cell phone is showing 100% short in meter reading, Now what should i do now to remove short from my cell phone's PCB?? Please help me.....
