Question about Home
Little water comes out my shower head when I take a shower, should I call a plumber, or is this something that I can fix myself?
When I take a shower, little water comes out the shower head, should I call a plumber,or is this something that I can fix myself?
  • 3,640 Answers
Remove the shower head. and if the water flows normal, its a clogged up shower head. if takeing a shower and the diverter valve goes bad. water will come out of the spout. check out shower head to see if its clogged. sometimes you can soak the head in a good cleaner and it helps it. but if its the showerhead thats plugged. you can always put a new one on also. good-day !
Posted on Mar 19, 2012
SOURCE:
  • 62 Answers
SOURCE: moen shower head leak
Single handle shower controls always have some water trapped inside. It has probably freeze damaged the cartridge
Posted on Jun 05, 2009
  • 68 Answers
SOURCE: low pressure on Delta 1400 series shower head
The Shower Valve is regulated to give only 2.2 gallons a minute. If you have the shower head off test how many seconds to get an approximiate gallon running in the middle hot/cold position. If longer than 30 seconds either the stem in the valve is clogged or the water lines to the valve are too small or kinked.
Phil
Posted on Dec 09, 2008
hessmar
  • 5 Answers
SOURCE: hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Posted on Dec 04, 2008
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
  • 50 Answers
SOURCE: We have a Maxx shower SA9592-02. The water comes
take a philips screw driver and take the screw out and flip the hot cold handle that should fix your problem
Posted on Mar 12, 2010
My Aqualisa Quartz shower stopped working suddenly. Pump is on, but no water
can offer no information on this but to call a local plumber .sounds like you possibly need a new pump
Aug 01, 2016 | Home
How do install delta shower
If you are looking to replace only the shower head, you'll need two plumber's wrenches, a cloth, and Teflon tape.
First and foremost, read the install instructions that come with the new shower head...
After you clearly understand what the instruction's say, shut of the water supply lines for the hot & cold water.
Take one of the wrenches and apply it to the neck of the water supply tube coming out of the shower wall (a.k.a. goose neck or supply nipple, or arm, depending upon the design). It'll have male threads (the threads are on the outside of the fitting). I would place a cloth of some sort around it before placing the wrench on it so you don't mar the finish of the water supply tube.
Place the second wrench on the shower head assembly (which has the internal, female threads). and unscrew it by turning the shower head assembly counter-clock-wise (to the left) while holding the water supply nipple with the other wrench.
You need to do this, so you don't snap or deform the water supply nipple coming out of the shower wall- and/or possibly causing leaky damage to the fittings behind the shower wall.
To replace the shower head, you reverse the removal process- the only difference is, you wrap Teflon tape around the male threads of the water supply nipple before spinning on the new shower head.
Somethings to be careful of, and I can't stress this enough, DO NOT cross thread the new shower head onto the water supply nipple. You should be able to screw it on the new shower head by hand- where it is hand tightened- then using the double-wrench method that you used to take off the shower head, turn the new shower head an additional half to three quarter turns with the wrench, clock-wise; and I mean gently.
Here's a nice short video on the subject, illustrating my instructions: http://youtu.be/fiv4Zq9v4co
Jul 27, 2014 | Delta Faucet Home
Low water pressure
The plumber who installed it originally may have installed it incorrectly.
Jan 22, 2014 | Home
Installation instructions plumbing
He put the wrong faucet in the cold-water side.. There may be a way to change the direction without changing the faucet... but, if there is, I don't know about it... I think you need to make the plumber come back and fix it right.. I had that problem in my shower after a plumber worked on it.. I almost burned myself to death trying to adjust the temperature.
Nov 19, 2013 | Cifial Hi-Arch Widespread Lavatory Faucet...
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Low pressure on Delta 1400 series shower head
Phil
Dec 05, 2008 | Delta Faucet Company RP26755 Sleeve...
Bosch Tankless HW Heater...Hot water flow becomes cold then hot again during shower. Have had only Bosch plumber in area out numberous times but never fixes the problem.
You are using a low flow shower head. you probably own the 250/2400 they have activation rate of .8gpm. If your shower head is low like this, your unit will deactivate. Higher flow shower head is a fix, or pull the aerator out of the shower head you have now might help.
Sep 23, 2008 | Terminator Aquastar 125FX Tankless Water...
Home Logo
182 people viewed this question
Top Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
