Sanyo  42 in. LCD TV Logo
A
Anonymous Posted on Jan 09, 2012
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Trying to program the dishnetwork remote with the sanyo tv's remote code. Sanyo is model number dp42647
dish guy
Level 2:
Scholar:
New Friend:
  • Expert 82 Answers
  • Posted on Jul 22, 2016
dish guy
Expert
Level 2:
Scholar:
New Friend:
Answers
82
Questions
0
Helped
33520
Points
310
To whom it may concern,
1. Point the remote in front of the desired television.
2. Press and hold the "tv" button at the top of the remote, until all the buttons at the top flash.
3. Type in "590" on the keypad.
4. Press the # key at the bottom of the keypad.
The tv button will flash 3 times. Your remote is now linked to your Sanyo television.
Best of wishes,
Dish Guy
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brian_142c5ec89a7a3fda
L Pfaff
Level 3:
Top Expert:
  • Sanyo Master 11,573 Answers
  • Posted on Jul 01, 2016
L Pfaff
Sanyo Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587233
Points
181713
Claude Kayser
Level 3:
Top Expert:
  • Sanyo Master 9,098 Answers
  • Posted on Dec 16, 2015
Claude Kayser
Sanyo Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066835
Points
28436
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
5 Related Answers
Anonymous
  • Posted on Feb 10, 2008
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Anonymous
  • 7 Answers
  • Posted on Jul 30, 2008
SOURCE: need codes for a Sanyo TV
0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
Anonymous
  • 374 Answers
  • Posted on May 25, 2009
SOURCE: need Sanyo TV code numbers
These are the codes for Sanyo TV'S for this remote. The newer TV codes are at the end so work in reverse order when inputting these codes. Thanks for using Fix Ya.
542, 589, 590, 591, 592, 609
Justin Smith
  • 135 Answers
  • Posted on Aug 23, 2009
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Anonymous
  • 208 Answers
  • Posted on Mar 19, 2010
SOURCE: Sanyo FXTG remote
Hi having a quick read trough the manual and finding the remote on the internet suggests this is the correct remote for your TV. The remote is not a universal remote so no programming is possible or necessary
How can i program my dish remote to my sanyo tv
beto_0423,
Programming a remote to your TV is an easy process, and I would be happy to help you with that! I have provided the steps below to help you with that along with a link to where you can get the codes you need for the TV based on your receiver.
Link: http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
If you're still having problems or need any other assistance let me know!
Tommy Faust
DISH Network
How do i control my hitachi tv with my dish remote
gregpayne67,
In order to control your Hitatchi TV with your dish remote you would need to program it. The codes needed depend upon the model of your receiver, though I can provide some general codes. Below I have provided some codes and a link for more information and the steps to program the remote!
Codes: 585, 638, 665, 668
Feel free to let me know if you have any other questions or you can email me at [email protected]
Tommy Faust
DISH Network
1helpful
Volume control on sanyo tv to dish controler
hy2277
I have provided a link on how to program the remote to your TV so you can control the volume and turn the TV off/on. I have also provided the codes available for your Sanyo TV. I hope this helps.
Instructions on programming the remote to TV:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Need free help. How do I program a dish network remote to operate my sanyo DP19648 tv? I lost the code sheet.
I hope that this has been resolved, but if not, here are some simple steps to help you out. The link below will walk you through a power scan. The power scan scans through the codes on the tv until it reaches the correct one.
Power scan:
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Here is another link to the codes for each brand of tv. You will need to follow these steps:
1.Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3-digit code
3. Press the Pound (#) button below the number 9 on the numeric keypad
4. Try to power the tv off/on, and try the volume. If one or all of these do not work, proceed back to step 1 with a different code.
5. Once all functions work, press the SAT button on your remote, and you are all set
Becki Barned
DISH Network Customer Service
1helpful
I need the code for tv Sanyo
It may depend on the remote. These are the codes for the 5.0 IR remote: Sanyo 590, 683, 589, 542, 652 . http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotehome.shtml lists all of the Dish remotes. Click on your model and then the link for the remote codes is on the left hand side of the page.
However, if your remote is older than your TV or was programmed within 6 months of the TV coming on the market, the code you need may not be included. In that case, you need a newer remote. (There is a time lag for the codes being provided to the universal remote vendors.)
I hope this helps.
As I program my control of dish to a tv sanyo
Hi maria_pal371, I would need to get a better idea of what model remote you have. I would recommend viewing our remote codes found here:
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
The model # is on the back of the remote at the top, once you have the code(s) you can follow these steps to program the remote:
1. Hold the gray TV button until all lights on top turn on.
2. Let go and while TV is blinking enter the 3-digit code you found and press #.
3. TV should blink a few times and stop. Try volume/power/mute.
4. If everything works hit SAT and you're good to go! If not repeat steps 1-3 with a different code.
Tommy Faust
DISH Network
213helpful
15answers
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Remote not working after programming
check the codes .. is it for your TV model or for general sanyo TV's ... if so try to look for the code of your model... please if you find this helpful rate me !
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
