Tried everything to +- to even them out but it didn't work. How do I remove the red streaks ? I have a 65 inch Mitsubishi Medallion HD1080. It just happened one day all of a sudden. Could it be the red lamp?
Red swoosh across screen. I used the remote to go into the menu to adjust the red convergence +- but it helps a little but red streaks are still there. Red swoosh across screen. I used the remote to go into the menu to adjust the red convergence +- but it helps a little but red streaks are still there.
its kind of hard to tell but it looks like your convergence chip (the red one) is shorted. usually about $250-$400 if you take to a tv repair shop.its kind of hard to tell but it looks like your convergence chip (the red one) is shorted. usually about $250-$400 if you take to a tv repair shop.
You can't post conmments that contain an email address.
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
possible fuse. if the red is curved or bent, if the red is straight try covering tv with blanket so the sensors get a good reading. again if the red is bent, and fuses are good..... bad convergence ic's.... local service center
im assumiong you checked the tint in the menu options. if not go check it. other wise it sounds like you have a weak tube, or you do not know how to adjust the screen brightness. this is how i adjust the brightness (you dont need to touch the focus). turn the red up until your whole screen is tinted red, then do the same with the blue and the green. then go through each one and turn down just a little till your pic darkens a little. good luck
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Yes the red tube is shorted. I will post a link to the site where I work as they have an entire AV48WP30 with a bad tuner they are selling parts off of including the Tubes. they also provide free info on how to switch out the tubes as a unit which is a fairly easy job. Heres the link.
every plasma tv ive come across with this symptom eneded up beeing a new panel. what i do is replace the x and y sustain boards and if that dont work youll need a new panel.
Here is a picture of it the streaks of red.
You can see the image above any clues what that is ?
