You have been so helpful in the past i hope you will again. the site you directed me to does not have my exact motherboard layout and i'm unable to find the proper directions to reattach everything needed to the board. what do you recommend??? thanks, steven
I am doing more research and trying to get the manual so please bare with me. I found a site but the manual is not downloading so I'm still looking for you. it seems there is a problem with getting your piticular motherboard manual but i will still be looking. one thing you could consider is looking at a motherboard manual that is simular to yours, because the pins and the RED FIREWIRE wire hook up will be the same, but I will continue on looking for It. also just a little hint on the pins , each set of pins on your board are very close to the intended connection , USB , AUDIO , ECT...
Ok ,I've done some more research and you should be able to use any of the same models pin out configurations the pin assignments are the same I have looked at the pinout specs.from different ones and the pinouts are the same just not in the same place on the board. Each funktion has a ground- and a positive+5 like the power button the reset button , hdd led , pwr led , speaker. The remote sensor will be the same hook up as will the rest, In these manuals they will illustrate what each hook up, pinouts , connections on the board will look like and how they should be connected. you can zoom in on the illustration to see better what they look like and what each pin represents and what is supposed to be connected . if you are having a problem hooking some of them up just let me know and I'll explain the connection.
these guys have gone above and beyond for me in the past. the fact the info i needed was not on the manufacturers site in no way effects the quality of service i received here. i am grateful for their assistance. steven
thank you for all you are doing. this particular board has usb, firewire, spdif, front panel audio, mic, usb and firewire. it also includes remote sensor as well as full display. the board is so crowded and the abbreviations are such as to require the manual. it is an atx mini and the board itself measure 7.5x8.5 so you see my delema. once again i thank you for your assistance. i'd love to know all you have forgotten. steven
thanks so much. i will download the manual for one of the 945 board schematics and zoom in on the pin config. you have been alot of help. i appreciate your efforts. steven
