SOURCE: maytag fav6800aww wont spin
I have a 3 year old neptune top load and have experienced the same problems you all have had here. Problem: Washer was leaking 1/2 gallon of water every load and sounded like a freight train on spin cycle. I usually do my own repairs but didn't have time so I called A&E by the recommendation of Maytag. Diagnosis! The tech said the tob o-ring seal was bad as well as the transmission. I had no reason to dought this professional right. I did after he told me the price... $450 to fix it!!!! I reluctantly gave him his $65 service call fee and said goodbye..
I called maytag and they said the transmission should have been covered by warranty (10 years). The tech was either an idiot or just plain trying to rip me off. I called Maytag back and they sent me the supposed bad tranmission and seals. I replaced them in 1/2 an hour. Guess what.... This did not fix the leaking or the loud spin cycle noise. What is the problem with this neptune model? The problem for every owner including myself has at minimum been the main seal inside the outer tub. This leaking for months took out the bearings causing the noisy spin cycle. I replaced both 6207-2rs bearings compliments of ebay for $6ea. After reassembly it was like new for the first load. On the second load it would stop on the spin cycle.... It would cycle between the agitators and trying to spin but never engaging into spin. After 5-6 minutes it gave me the code that stated an unbalanced load. What the problem was is the leaking had made its way into the clutch as well. I pulled the clutch/pulley back of and cleaned and lubed it. Problem solved! She now goes into spin and has no problems whatsoever. I'll never call A&E again...Mechanically this washer is a piece of cake to work on. Electronically it could be a bear... The bearing replacement took approx. 2 hours total from start to finish. Next time I'm buying Kenmore and the extended warranty. I'm tired of screwing with this junk... Good luck guys.... Jos Roach... CA.
SOURCE: Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin
Hey Cameron,
I saw you post today on another forum and did not have time to put my thoughts down before work. I agree not a clutch issue I had to :), you would be so lucky. I own the machine and can’t offer any more troubleshooting then what you have done, good job of that. Unfortunately the FAV6800AW/FAV9800AW SM doesn’t have a whole lot of support for troubleshooting beyond what you have done for this issue. I found more info from the MAH3000 manual on the technical operation of the motor controller (slightly different controller). Both machines use the same troubleshooting paths. Remove JP4 which is;
P1 Motor Control common
P2 Torque (to Motor Controller) see page 1-11 MAH3000
P3 Motor Control Tach (to control board input)
My WAG is replace the Motor Controller 1st, then Control board 2nd and a possible tach issue related to the motor. That’s enough WAGing,…. but with troubleshooting not a complete WAG :).
Take a look at pages 2-5 thru 2-11, I keyed in on page 2-11 in the MAH3000, it may give you some additional insight, I know we are dealing with different machine designs but I think the designs are close regarding motor controller, the motor and what the Control Board is doing and looking for with input from the Motor Controller. I wish the FAV6800AW/FAV9800AW SM gave this kind of detail for troubleshooting. There is a nice little troubleshooting table on 2-11.
I keyed in on this note;
The motor control monitors the signals and communicates this information to the machine control (control board). The purpose of this signal is to tell the motor when to energize each winding in the motor and to tell the machine control the actual motor speed.
Then this note;
Note: If the machine control board does not receive an input signal from the motor control/tachometer circuit (JP4 connector), the motor speed will rapidly accelerate for 5 seconds then shut down. The machine control will sense a "locked rotor" condition and the motor will stop. If the motor control does not receive an input signal from the motor, the motor will "****" for 5 seconds then shut down.
I don’t believe you have that condition. I have worked with a forum member who had an issue with the motor controller related to an Lr error, locked rotor error and replacing the Motor Controller fixed the issue. Form here I vote for an issue with the Motor Controller. Not having known good parts makes this a difficult job.
The control board is under warranty for 5 yrs from DOP, the Control Board is 2 yrs. Ebay is a good source 25001079
I would push Maytag CSV for both. I got them to send me a Control Board after discussing my troubleshooting and that I had a neighbor (me) that was a repair tech who would install. I also had to send them copy of my warranty not sure why they beeded that my machine was on file with them.
In your console you will find a Troubleshooting guide if you haven’t pulled it out already. It has the schematic for the machine which I find handy. If you want a soft PDF copy of the schematic I can e-mail you. Just ping me at [email protected]. I use that for one-way contact, just respond back on this post if you ping me, I don’t check the account for month’s at a time.
With my limited knowledge I will try to help you. Good luck. Rich
Testimonial: "Awesome help and advice -- thank you to everyone!"
SOURCE: what is the Central Control Unit (CCU).
it's probably the (MCU) motor control unit you can find it at REPAIRCLINIC.com item #1184161 cost is $176.40
SOURCE: My Maytag Neptune Top Loader
My washer just started doing the same thing? Have you fixed the problem?
SOURCE: I have kenmore elite HE5t.
F-22 is: CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Take the top panel off, should be 3 screws on the back of the top panel.
Then look at your CCU, and remove the wire connections from it and
inspect the wiring in the connectors to make sure non of the pins are
broken or burned. Then reset all the connectors back to the CCU and see
if that fixes it, if not then your CCU would need to be replaced.
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touch-pad/LED assembly and Central Control Unit (CCU).
The part number on the CCU can be looked up and purchased from here: http://www.repairclinic.com/Shop-For-Parts
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
