Question about Kenmore 42800 Stainless SteelCooktop
Error codes 10 12 16 on kenmore induction cooktop
Seems as though sears does not know what these codes are, without sending a repair person, codes can be reset by turning off breaker and repowering.
  • 1 more comment
  • deanu Oct 12, 2008
    I just installed a Kenmore 30" induction cooktop, after about an hour all burner controls displayed E and the main control flashed 10 16 12 repeatedly. Cycled power and returned later.
  • Sheila Lewis Jan 29, 2009
    I have exactly the same problem...no answer to the 10 12 16 error codes in the use & care guide supplied with the cooktop...good thing I bought the extended coverage on this baby. We found that if we turn the power off and back on we can go for several days before we hear beep-beep-beep in the middle of the night and see the "E" flashing for each burner and the 3 error codes alternating!
  • Anonymous Mar 25, 2014
    Kenmore Elite Induction Cooktop PF error code
    New Friend:
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
Posted on Dec 05, 2009
SOURCE:
I have a Kenmore Elite Electric Range with Induction Cooktop #C970-440032 with an error code E074
Suggest down load the owners manual online and reference error codes.
Mar 21, 2018 | Kenmore Cooktops
What does Error code 35 on an induction cooktop mean
A quick web search of "Error code 35 induction cooktop" seems to indicate a possible bad control board in the unit, but you would need to get more specific about the make/model of the unit to know for sure. A Google search should help you find the answer but that seems to be the most common one and mostly relating to Kenmore units.
Feb 18, 2015 | Cooktops
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Nov 10, 2013 | Kenmore 30" Induction Cooktop Stainless...
Reassembling a Kenmore 30 in. induction cooktop
The best way to understand how its installed would be to check out its user manual. Since you have not provided the exact model number I was unable too narraw it down to help you with correct manual. But please click on the link bellow to download the appropriate manual:
http://www.hammerwall.com/Manuals/Kenmore/9-36/Lookup/Home%20Appliances/65/
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Apr 06, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Feb 01, 2009 | Kenmore 42800 Stainless SteelCooktop
Kenmore 42800 Stainless SteelCooktop Logo
1,709 people viewed this question
Top Kenmore Cooktops Experts
jdthefixer
mcgsp
Level 1 Expert
Kolbrun...
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
