Stanley 77 115 Intellisensor Plus Stud Sensor Logo
A
Anonymous Posted on Jan 09, 2012
Service manual for a 77-115 stud sensor 150 - Stanley 77 115 Intellisensor Plus Stud Sensor
Red light doesn't go off on stanley studfinder
Hi Laurie,
I think you might have confused the calibration set up in the first step of the directions. This must be done each time the unit is powered on, placed on a different wall, or whenever it is providing ambiguous indications. For you convenience, I have pasted the operation manual below. You should download and review the entire manual - free of charge here.
1) Hold the Stud Sensor 50 flat against the surface making firm contact.
2) Press in and hold the activation button. The green
and red LED's will light. When the red LED goes off,
the unit is calibrated
. Keep holding the activation button
during all of the following procedures.
Note: While calibrating, the Stud Sensor 50 must not
be placed directly over a stud, dense material such as
metal, or over a wet or newly painted area, or it will not
properly calibrate. If the Red LED stays lit, move to
a different location and try again.
2) Slide the Stud Sensor 50 slowly across the surface
in a straight line. As it detects a stud edge, the red LED
will go on.
Use the handy pencil notch located at the top of the
unit to mark the stud edge.
3) Repeat the above steps from the other side of
the stud. Coming from the opposite direction, mark
the other edge of the stud. The midpoint of the two
marks indicates the stud center.
Cautions on Operating
The proximity of electrical wiring or pipes to the surface
of the wall may cause the Stud Sensor 50 to detect
them as studs. You should always use caution when
nailing, cutting or drilling in walls, ceilings and floors
that may contain these items. Always remember that
studs or joists are normally spaced 16 inches or 24
inches apart and are 1-1/2 inches in width. To avoid
surprises be aware that anything closer together or of a different width may not be a stud.
I hope this helps & good luck!
Performance Tool Digital Tape Measure W5746
http://www.irwin.com/uploads/documents/30_intersect_laser_level.pdf
If that is not the correct one, check here:
http://www.irwin.com/support-services/product-manuals
I can't find my user guide, What settings do I use for stud finder?
Hello. The instructions can vary from model to model. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
If this answer has helped, please rate it a four-thumbs up. Thank You.
How do i find a stud with the stud finder
1helpful
2answers
How do you know when the strait line laser level and stud finder is on a stud
Hello. The instructions can vary from model to model, but most have a green indicator light that lights up when the unit detects a stud. There is a section in the manual (for most models) that will show/inform of the unit's individual method. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
Strait-line
Yes. The lights represents the stud. As you move it over each light lights up.
2helpful
How do I know when i am on the stud
These usually need to be calibrated in a stud-less section of the wall so that the LED just goes out. Slide the finder over the wall slowly until the light turns on--that is the first edge. Continue moving and the LED should go out--that is the second edge. These two points should be marked lightly with a pencil and the midpoint between the marks locates the center of the stud. Note that these tools will respond to wiring in the wall the same way. Hope this helps!
Need instruction manuals
you can find manuals for power tools such as the stud sensor at http://powertool.manualsonline.com/
Broken lug nut stud
Go to a NAPA store and either ask them, when you buy the studs...or buy a Chiltons manual $20 and read
Good Luck
Top Stanley Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
