Question about HP Photosmart C7250 All-In-One Thermal Printer
HP Photosmart C7250 lines in photos
I'm getting lines (slightly lighter than surrounding color) in photo quality printing in my HP Photosmart C7250 printer. Running an "Alignment" operation in the Printer Utility solves the problem for one or two print jobs then it's back. Suggestions?
  • Steven Jaynes
    Steven Jaynes Jan 09, 2012
    BTW - Ink cartridges in this model are JUST reservoirs and have nothing to do with Printhead alignment. Their flow path can become dirty or clogged which starves one or more colors, but that will not cause evenly spaced lines over an image with changing colors. These lines appear irrespective of color being dispensed.
  • Steven Jaynes
    I'm reasonably certain the Printhead will require replacement, but need a pointer to instructions. I am a former printer technician so know what I'm doing, just don't want to charge in where a few key instructions can save time and embarrassment.
  • HP Master
  • 1,121 Answers
Replace print heads.. For draft or letter work you can adjust with this print heads, but photo prints you need good healthy conditioned print heads.. as per you info you did every thing rest only thing to replace..
Posted on Jan 09, 2012
  • Vinaya Kumar Kuchipudi
    Vinaya Kumar Kuchipudi Jan 10, 2012
    Things to need to clean print heads manually:
    1. Little temp Warm water
    2. alcohol
    3. cotton or ear buds
    4. tissue paper.
    Process: take out the print heads, dip the nozzles in to the warm water wait 3-5 minutes ensure that water should not touch the print head contacts and memory. take out print heads clean with tissue paper gently on the surface of the nozzles, dip cotton/ear buds in alcohol swab on nozzles, shake print heads and observe that ink is coming out?.. . install print heads in printer perform print head cleaning check nozzle test.. if satisfied .. end.. other wise repeat this process 2 - 3 times.. you will get good results.. best of luck..
5 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: blurred and fuzzy print quality
i think you use a compatible ink... use genuine ink for epson ok...
Posted on Feb 18, 2008
leroyal
  • 2120 Answers
SOURCE: HP Photosmart printer 3180 prints alignment page at start up
Replace all ink cartridges to get a successful alignment.
Posted on Feb 25, 2009
efs_perpends
  • 1996 Answers
SOURCE: Print Quality Poor - HP Photosmart 2575 All-in-One
You can download the manual from Software & Downloads here.
Then work through this article and see here to diagnose the printing problem. Make sure the print quality is set for photos in the print preferences or properties.
You might try cleaning the cartridge contacts as described here.
Make sure you are using a good quality paper, that it is feeding correctly,
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 30, 2009
  • 685 Answers
SOURCE: have hp photosmart 4480...continues to
Try this and let me know how it works?
Posted on Nov 10, 2010
HP C7250 w Vista PC inserts a blank page between every printed pg
You have told it to print a "seperator page"
your hp software has this setting and you need to turn it off
Aug 22, 2009 | HP Photosmart C7250 All-In-One Thermal...
Jul 30, 2009 | HP Photosmart 2575 All-In-One InkJet...
Last line or two of print gets cut off
I have seen this suggested in a HP Support Forum. See if it solves your problem:
1. Go to your printers folder, right-click on (the network connected) printer that you are having the problem with and select "Properties"
2. When the properties window opens, click on the "Ports" tab.
3. Near the bottom of the Ports tab window is a check box for "Enable bidirectional support", uncheck it and click "OK"
Jul 29, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP Photosmart c4480 - poor quality photo prints
you shoud test printhead,if they are ok, you choose "best photo" in printer property.
Jun 26, 2009 | HP Photosmart C4480 All-In-One InkJet...
Last line getting cut off when printing
go to control panel and click on printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see this website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Mar 31, 2009 | HP Photosmart C7250 All-In-One Thermal...
Poor color print quality HP Photosmart 2710 all-in-one
yes..do a clean heads and re calibrate..if you have print manager, it can be done from there.
might be able to get them through this printer driver link
Mar 09, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart C7250 All-In-One Thermal Printer Logo
183 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
