My Insignia Bluetooth Wireless Headphones is not getting charged.I bought it in USA..I am using it in India..Its not getting Charged.
If you mean the Insignia NS-BTHDST or NS-BTHDP, I read elsewhere in this forum that you can reset it and that might work. See the manual. Basically you hold the volume up and volume down together while the charger is plugged in. The instructions were vague and mine did not reset nor show a purple light as indicated in the manual.
However, after trying that a couple of times, I accidently got it to work by pressing the phone/play button twice. Press it normally, not the long press you use to turn it off and on.
So in other words, plug it in to the charger. Press and releas play. Press and release play.
For me, the charge light turns on and it starts charging. I hope this helps.
Mine is new too, sort of. It was an "open box" from an ebay seller. I may return it anyway, since it is clearly NOT behaving correctly. You shouldn't have to press buttons at all to get it to charge. I know because I have another one.
Bon chance, mon ami.
Well, its not a solution, but a comment... i bought it on USA and brought it to Brazil and had the similar problem... the french guy tip was usefull, cause i put it to work, but my red light does not stay on as i put it to charge. I believe that the red light only stays on if the device is completely in need to be charge... as i let it charging for days, maybe now is not in need... but i agree, this thing does not work as it supposed to do.
Its not getting charged
