Help!!, I need the white rubber seal that goes under the secondary filter (that seals the bag cover at the bottom) It looks like it slides onto the top of the motor front cover. Mine is ripped and will not create a tight seal anymore and I am losing a lot of suction. Thanks! Mona
SOURCE: Oreck XL Leaks Dirt At Bag Entrance
do you use a docking station to put your bag on or is it just a push on bag? also when you turn on the vac with an empty bag in it, does the outter bag blow up?
SOURCE: no suction
Replace your belt. Remove the baseplate, remove the brushroll, place a new belt around the motor pulley, then around the pulley on the brushroll, and pull the brushroll back into place in the nozzle. Spin it by hand to make sure it spins, (otherwise you'll break the belt again,) and then replace the baseplate. Party.
-R
SOURCE: Lost suction after I changed the bag and cleaned the air filter
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
SOURCE: Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
SOURCE: I have a canister vacuum. I replaced the bag and
The case that encloses the bag may not have been closed properly, or a part of the bag got caught in the seal of the case. Take the bag out and reinstall. Hope this helps!
