SOURCE: Canon i860 "printer offline" but light is blinking
Move mouse pointer on to your printer icon in the Printer folder. Does a right click and click on the sixth line of the menu (“Use printer on line”). Then it will change as “Use printer offline”. Make sure the printer is set as default printer.
SOURCE: Printer is offline to one computer but not other.
Ok what you need to do is network the 2 PC's together using a crossover cat5 cable ( can be purchased at Radio Shack). If you don't know how I can explain how to do that also.
Once that is setup one of the PC's with printer driver needs to be shared so the second PC can access. As long as PC 1 is on both PC 1 and 2 can print without issue.
I can be more specific if necessary
Hope this helps,
TankMurdock
SOURCE: False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
SOURCE: Canon Pixma MP190 all-in-one will copy offline and
this sounds like a virus any ways, make sure u have a very good antivirus, remove and reinstall the printer with the driver but first go to the printer delete all the printers installed manually i.e after uninstalling the printer and its still showing the printer at printer and faxes, then reinstall it.
SOURCE: My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
