The units acc wire was ran to 2 monitors and one of the wire coming from the wire harness the acc wire touch metal and everything turned off. changed fuse from the engine compartment and sealed wire that touched metal but know it has a loud winnig sound coming threw my speaker with just the ignition key to on.When i turn car on it triples with the noise and when i shut the stereo off it makes a big popping sound. So i wanted to know if the resistor feom the acc wire from the pioneer unit goes bad after a short or is the radio the problem? please let me know asap what it can be because if its the resitor from the acc wire i will order a new harness. i will apreciate any info. thanx. my email is [email protected]
The recent pioneer DVD devices structures setup is achievable by inspecting the vehicles default wiring kits to determine the most compatible medium. The prior wires in the vehicle stereo appear mutated with attempt to extract and replace with new DVD stereo. Inspect the mutilated wires to determine the kit harness that allows connecting the new device on one end while binding to the electrical cables extended surfaces. The new stereo player makes possible connection of a multipurpose harness that solves the problems that may be thought to require bypass. Once the appropriate connection kit harnesses are acquire, the wiring should provide connectivity to speakers, tweeters, woofers and several devices as amplifiers also necessary predicted during installation else missing audio may be detected after. Refer to auto installations experts to acquire the complementary parts to attain the installations.
