Mitsubishi WD-Y65 65" HDTV Logo
Anonymous Posted on Jan 08, 2012
View 3D on wd-y65
Bought Panasonic Blu-ray 3D player, can't get 3D picture on Mitsubishi WD-Y65 television. How to adjust settings to view movies in 3D?
  • 3 more comments
  • Anonymous Jan 08, 2012
    Thanks, Bhujbal Swapnil! So, you're saying, get Power DVD for pc, & can view 3D, k. I have a standard DVD burner/player built into my pc, & 3D is Blu-ray format. How do you run a Blu-ray player thru pc to convert signal? I have HDMI out from pc to my DLP, but dk how to run player through pc. Would gladly purchase DVD 11, if I could figure out how to play Blu-ray player through my pc. Any hints?
    I meant: Power DVD 11.
  • Anonymous Jan 09, 2012
  • Anonymous Jan 11, 2012
    I got Power DVD 11 as suggested, but as I suspected, w/only a standard dvd player in my laptop, it couldn't read Blu-ray 3D or any other Blu-ray discs. I was told that this software could enable 3D viewing even thru an older crt type tv, but I have no idea how to apply it to view the discs w/out being able to run the external Panasonic 3D Blu-ray player through my laptop to perhaps utilize the software I downloaded onto it (which I can't figure), or scrap the idea altogether. Is there no way to use a perfectly good 3D Blu-ray player to view a 3D disc in 3D through my WD-Y65? I was told my question needed more detail. I hope this will suffice. Thanks.
    Btw, my Panasonic Blu-ray Disc Player model # is: DMP-BDT210. Thanks again.
Vinho Xie
Level 3:
Genius:
  • Mitsubishi Master 1,419 Answers
  • Posted on Dec 29, 2021
Vinho Xie
Mitsubishi Master
Level 3:
Genius:
Answers
1419
Questions
0
Helped
414076
Points
4431
In the following article we will introduce several ways in which you can easily convert a 2D movie to Anaglyph 3D, so that you can enjoy your own hand-made 3D movie today.
Article: Make 2D to Anaglyph 3D Movies with Anaglyph 3D Maker
Dillon Sherma
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 33 Answers
  • Posted on Jan 08, 2012
Dillon Sherma
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
33
Questions
0
Helped
3581
Points
74
Ur tv does nt support 3D. U can still see 3D if connected to PC. With power DVD 11 u can able to watch anaglyph 3D.
Dnt get confused any standard screen (e.g. CRT (big boxes with curved screen)) can view anglyphic 3D content.
5 Related Answers
Anonymous
  • 1030 Answers
  • Posted on Apr 04, 2009
SOURCE: What causes my mitsubishi WD-Y65 tv to keep
thermal sensor problem.... there is a service bulliteen to service shops about this.. this generally a warranty item that is covered.... you will have to get a tech to see if its covered. the thermal sensor needs replaces.not to difficult to replaced
Anonymous
  • 64 Answers
  • Posted on Aug 01, 2009
SOURCE: my mitsubishi wd-y65 has sound but screen is black
You are SURE the lamp is good....well...if you say so. However, it sounds like you have made audio connection but no video connection (or lost it or is incorrectly set). Try other input modes. See if you an bring up "setup". If so...you screen/lamp is working.
Anonymous
  • Posted on Feb 23, 2010
SOURCE: hdmi 2 wont work on mitsubishi wd-y65
It sounds similiar to a problem we've had with ours, all components would work in hdmi 1, but hdmi 2 would only work intermitently. They ended up replacing the digital board (fortunately we have the extended warrenty, I'm sure it's not cheap). Sorry hope this helps.
Anonymous
  • 1476 Answers
  • Posted on Aug 21, 2010
SOURCE: How do I replace the
hofferberr,
I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to change the lamp, why when to change the lamp and where to get the best lamp at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Anonymous
  • Posted on Dec 20, 2010
SOURCE: wd-y65 dlp, have sound,
sounds like you need a new bulb, mine is doing the same and the lamp light is coming on.
Wd-y65 no picture. Sound for a few seconds then shuts off
Lamp is usually customer replaceable and instructions are in owner manual.
I would to begin with (set unplugged) get at the lamp to inspect it--if shattered inside look for a replacement.
Google the model number with "lamp" to see what is available.
You Tube has video instructions for replacing lamps on most brands and models as well---not have to read just look.
How do I view movies in 3D on the Mitsubishi WD-Y65?
WD-Y65 is NOT a 3D ready TV. You either have to change the TV to see the movie in 3D, or just watch it in 2D in you current TV.
I have the same TV as yours. Current I connect a desktop PC to the TV via DVI port, and I watch Avatar using colorcode 3D(Amber/Blue) with Stereoscopic Player from www.3dtv.at It might be a way for you to enjoy 3D without change the whole thing, but it's an entire different topic.
2answers
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Wd-y65 dlp, have sound, no picture, tv shuts down after about 30 seconds. tryed tv reset 3 times,did nothing
How do I replace the bulb in my Mitsubishi WD-Y65?
hofferberr,
hardrocko
Hdmi 2 wont work on mitsubishi wd-y65
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
