SOURCE: hotpoint washing machine model aquarius+1200 spin wf620
F03 indicates an open or short circuit thermistor, this is associated with heater element, so probably the water is not getting hot.
You need to check the heater and thermistor unit. access is from the rear.
Hope this helps.
Plz leave feedback
Ta.
SOURCE: hotpoint washing machine aquarius super silent wf620
Dear stacey
Had a similar error message
turned out I hadnt turned the water taps on
check this and if not the problem could be the water sensor in the drum
G
SOURCE: Hotpoint washing machine model WF620, keeps
depending on which version you have to
Press the 'Start / Cancel' button until ALL the console LEDs illuminate.
then either
1.Press both 'Start / Cancel' and 'On / Off' buttons together until 'd OFF' appears.
or
2. Press 'On / Off' and 'Start / Cancel' together with the top left option button (Spin) until 'd oFF' appears.
SOURCE: hotpoint aquarius wf620 washing machine,machine
While spinning every washing machine is very noisy as it rotates in very high speed.This is normal and no need to worry.
Thank You
