Inherited a baby leapfrog learn around playground but we don't know how to use it
SOURCE: How do I remove the legs from Leapfrog Musical Table
Turn the table on its side. On the top of the outside of the legs are two slits, where they connect to the table. Slip a butter knife in the area between the slits, and press in (not up or down) hard! The legs will pop off in a few tries if you do it hard enough :o)
Tried the knife option and it broke the plastic, I'd recommend the end of a spoon option, doesn't break the plastic and comes off ina few seconds - not easy though!
SOURCE: need instructions and don't know
Hi Bonnie,
Here is a webpage that has a spot where you can download the user guide: http://www.buzzillions.com/reviews/kids-nickelodeon-delta-dora-explorer-toddler-bed-model-no-bb-86615do-reviews#Description
Look on the left hand side under Features. There's an Adobe Acrobat icon that you can click on and download the instructions.
My computer is a bit old and couldn't download the instructions. In case you have the same problem, here is Delta's contact page: http://www.deltachildren.com/customer_care.asp?pg=assembly
They should be able to help you get the bed together.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
SOURCE: I'm using Windows 7 64-bit.
I am having the same problem, contacted Tag (who is only there during work hours which really does not help) they supplied me with an alt connect file. That did not work either. Have you found a solution yet?
Kat
