Stanley Fatmax Xtreme Retractable Utility Knife Logo
A
Anonymous Posted on Jan 08, 2012
Loading blades into a fatmax 10-777 - Stanley Fatmax Xtreme Retractable Utility Knife
3 Related Answers
Anonymous
  • Posted on Apr 11, 2010
SOURCE: Just purchased a Stanley FatMax 10-778 retractable
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Testimonial: "Thanks so much!"
Anonymous
  • 127 Answers
  • Posted on Dec 27, 2010
SOURCE: describe how you put a blade in FatMax model
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Anonymous
  • 710 Answers
  • Posted on May 10, 2011
SOURCE: When I inserted blade into
Hi Betsy,
Please go to this webpage and read the rants about this product.
Down towards the bottom are reviews written mostly by contractors and such. Review number 3 addresses your problems exactly. http://www.crunchgear.com/2008/12/05/review-stanley-fatmax-utility-knives/
Good luck
Handie Andie
How to change the blade on a fatmax mitre saw fe721
You have to loosen, NOT remove, two bolts on the blade cover so it rotates just enough to give you access to the spindle bolt holding the blade on. Check this web page for the user manual. You'll need the pictures on page 5 and the description on page 14 of this manual.
https://www.manualslib.com/manual/966235/Stanley-Fatmax-Fme720.html?page=14#manual
Jun 08, 2023 • Blade Saws
Can't close stanley fatmax
It only goes in one way, try to loosen the screw a little
How to open stanley fatmax knife 10-778 TO CHANGE THE BLADE. thank you
How do I change the blade on the quick change/instant change knife? Warning: Blades are sharp and can cause serious injury. Be extremely careful when handling blades. Wear eye protection and dispose of used blades properly, such as wrapping in duct tape.
FULLY EXTEND THE BLADE.
Press down and forward again on the slide button until the button is in the full front of the top slot (0 through 3 in the below picture).
Note- the blade must be extended beyond the 3rd detent position. This will cause the slide button to remain in a down position, allowing the blade release button to operate.
PRESS AND HOLD THE BLADE RELEASE BUTTON ON THE FRONT SIDE OF THE KNIFE. (Step 4 in the below picture)
Note- if the blade is not fully extended beyond position 3) , the blade release button will not work.
Remove the old blade carefully.
Insert new blade.
NOW, RELEASE THE BLADE RELEASE BUTTON.
ENSURE THE BLADE IS LOCKED IN PLACE. If the blade does not retract, try carefully giving a slight tug on the blade to reseat.
I just purchased the FATMAX Utility Knife -- Looks nice, but how do I load the blades? Better yet, when I load the cartridge (finally figured that one out on my own) I can't get the blade to...
the blade section pivots to swivel when doing that it allows you access to the blade storage area that holds up to 7 blades, if the extra blades arent in place perfectly the handle won't close properly, if your problem is with the blades themselves, make sure that the slot in the blade is aligned with the holder perfectly
5helpful
2answers
Loading instruction to change blade on Stanley FatMax box cutter
Hmmmmm.... that sounds really confusing.
Better yet... just watch this video! http://www.youtube.com/watch?v=B8Q1p-8jkyE
It's actually pretty easy! :)
I have a stanley FatMax. How do I insert the blade into the case?
On the side there is a big gold wheel, twist counter clockwise and the case should split in half, the blade is held by a magnet, prise the old blade off and replace with new one, then put case back together and tighten gold wheel clockwise
11helpful
Describe how you put a blade in FatMax model 10-778
163helpful
3answers
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
good luck
I brought a stanley fatmax retractable knife, have no idea why the blade is not coming out, trying to figure out if i did something wrong like putting the blade in the wrong spot.. this is the only time...
Are you using Stanley Blades or off brand? Hey, I use off brand but sometimes it does make a difference. Second, make sure the blade slider is clean. If you were cutting shingles, for instance, the tar gets in there and screws things up.. try WD-40 spray it liberally all over the blade slide and buttons. If that doesn't work and you purchased it at a Menards store, I can speak of experience they'll replace it no hassle.
I hope I helped
Top Stanley Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
