My Dance Star Mickey stopped talking. I've read somewhere that there is a panel on the foot that activates and deactivates his voice. Is this true and if so, where is it as I am unable to locate it?
I just had this same problem. Micky danced and moved his mouth but no sound. I opened up Mickey's outfit at the back of the neck up to the top of his head and found a broken wire. I spliced the wire back together and Mickey works again! The 2 wires go from the back center of Mickey's head to the top of his left shoulder. Hope this helps someone else!
SOURCE: i recently purchased a Dance
I know this is going to sound smart allecky, but try changing out all of the batteries in both feet. The ones that come in it do not last long at all.
SOURCE: Dance star Mickey won't move
Did you get it to work? I am having the same problem with the one that our daughter got for Christmas. The demo tab is pulled out but Mickey acts like he is still in demo mode. We have already changed the batteries..
SOURCE: Dance star mickey won't work.
Mickey has a button on top of HIS left foot that starts the other dances. It took me 3 days to find it, I threw the box away also.
SOURCE: Dance Star Mickey only sings
Hi schaefer4647
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
BEFORE YOU BEGIN
-Remove and discard the "Try Me" pull-tab, located on
Mickey's right foot next to the battery compartment.
Once the TRY ME pull tab is removed, the toy will
perform its full play pattern as described below.
-Be sure the ON/OFF switch is in the ON position.
The ON/OFF switch is also located on Mickey's right foot,
HOW TO PLAY
There are 2 places where you can press Mickey to begin play:
-LEFT HAND
-LEFT FOOT
Press either place to begin play.
There are 2 ways to play with Dance Star Mickey:
DANCE MODE
Press Mickey's foot to see him perform
one of 6 different dances!
-TECHNO
-MAMBO
-MOONDANCE
-"SHAKE YOUR GROOVE THING"
-"GET UP OFFA THAT THING"
-"M" TO THE "I"
GAME MODE
Press Mickey's hand to alternate between 2 games:
-Mickey says
Follow along and repeat Mickey's moves -
but only when he says "Mickey says!"
-Freeze dance
Dance to the beat when Mickey says "Go".
When he says "Stop", you freeze in place!
