Watches Logo
Anonymous Posted on Jan 07, 2012
Operating instructions for tag heuer caf1010
Model caf1010
5 Related Answers
Anonymous
  • 2501 Answers
  • Posted on Mar 02, 2010
SOURCE: I need to know how to use my cl1112 Tag Heuer
Copy "ww2.tagheuer.com/_documents/manuals/EI2246_en.pdf"" into your search engine and it will take you to a generic instruction manual for TAG watches.
This manual includes instructions for operation of your watch.
Anonymous
  • 51 Answers
  • Posted on Oct 25, 2007
SOURCE: Tag Heuer Formula 1 Mens watch
This is not a cheap watch....You should send it to a qualified watchmaker or the manufacturer. This watch has to have a pressure test to insure it's water tight. This may require replacement of some or all of the gaskets in the case.I would never recommend that this is something that you should try to do yourself.You would be amazed at the money I make do to improper replacement of JUST the battery.
Donald McPherson, Certified Watchmaker AWCI
www.finewatchmaking.com
WWW.AWCI.Com
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Dec 31, 2008
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Ron_Ray
Ron_Ray
  • 13 Answers
  • Posted on Mar 31, 2010
SOURCE: I have a Tag Heuer S29.006M and no idea how to
This may help...
http://www.tagheuer.com/_documents/manuals/EI2245_en.pdf
and...
http://www.chronomaddox.com/heuer/manuals/pilots/pilots_manual.html
It's probably not your exact watch, but maybe the functions are the same.
Anyway, I hope it help.
walesarumi
Wale Sarumi KomputerSolution
  • 6993 Answers
  • Posted on Dec 03, 2010
SOURCE: Manual for TAG HEUER AQUARACER
unfortunately, the manual for your
TAG HEUER AQUARACER 2000 CHRONOTIMER MENS WATCH is not available anywhere online. The manufacturers of this watch did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of your
watch via phone or e-mail and request for the manual from them. They might give it to you or direct you to a dealer where you can get the manual.
This is the best you can do to get the manual you are requesting for.
Good luck.
Instruction manual
If the second is ticking as normally it is not the battery. If the battery is low the second hand will advance only at 5 second intervals meaning for four seconds the second does not move and on the 5th second it will advance by five seconds. This is a feature unique to Tag Heuer.
5helpful
I need an instruction manual for a Tag Heuer 50 Chronograph Aquaracer mens watch
Tag Heuer recognizes manuals by watch caliber number, not the watch model. Browse through my Tips and Tricks. There are few Tag Heuer watch manuals. Check out if this can help you.
Feb 24, 2011 • Watches
2answers
Tag heuer wk111a-0 instructions
This watch has ETA movement.
The instruction for the watches with the same movement is in
http://www.old-omegas.com/1665en.html
1helpful
How to setup the alarm to my tag formula1
I couldn't locate your model but if you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1113.BA0850 , you will find the details of a similar watche. In the menu at the side you will see "instruction manual".
Mar 01, 2010 • Watches
1helpful
Tag Heuer Formula 1 with alarm WAH111A.RWV3350
You can find the instructions on the Tag wed site (www.tagheuer.com), select "watches" then "formula 1"
then "man" and then the model of your watch.
On the right of the page is a small menu,select "user manual"
Feb 09, 2010 • Watches
My alarm does not sound on my Tag Heuer Kirium F1?
Have you a copy of the manual?
If you have, then you will see that it can be turned off (last page), is this likely to be the case?
If you need a copy, go to their web site "tagheuer.com", select "watches", then "tag heuer formula 1", then "man", followed by "Tag Heuer F1 chronometer" and finally you will see on the right a menu, select "user manual".
This seems to be a generic manual that cover both the chronometer and alarm version of the watch.
If these are not the correct instructions for your watch, opposite the "user manual" menu is a search box, put your watch model in this and there should be a user manual with it.
If not look at a similar watch for a generic manual.
Top Tag Heuer Watches Experts
k24674
Sean Wright
Sean Wright
Ngoro
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
