Question about Kohler 12 kW Emergency Power System - 12RES-L
Kohler 12kw generator starts but shuts down after 3sec
I just installed a kohler 12RESM! natural gas generator and after starting, will run to high revs and then shut down, the code on the display is U U
Any advise, my gas pressure in is 8"wc.
  • 6 more comments
  • radioflier Oct 09, 2008
    I need a technical solution that is more specific and is not contained in a sales brochure.
    This is not a portable generator that can be unplugged..
    Check the module for what?
    still does not solve my problem..
  • wchorne Jan 17, 2009
    I also have a 12RES Kohler generator. It has operated well for two years, but for the last two weeks has been shutting down about thirty seconds after it starts to exercise. It also shuts down about thirty seconds or so after I start it manually. The oil level is OK. I am not sure about the natural gas pressure in the system, but it has been below freezing around here during the times I have had the problem. After it shuts down, mine also reads UU and then 52.0. I have had a HB (high battery) reading for almost two years, but that never has caused it to shut down and has never stopped it from exercising on schedule. The battery charger has a green light on it. I suspect low gas pressure, but the local gas company tells me that they are keeping it up. Not sure of this.
    --Bill in Salisbury
  • Anonymous Mar 13, 2014
    20kw generator revs up and slows down constantly, sometimes quitting. checked air filter, changed plugs, checked valves, checked connections on control board. The governor works constantly. This unit runs off natural gas.
  • Anonymous Mar 27, 2014
    Kohler generator 60 HUC where is the oil pressure sensor
    Kohler generator 60 HUC where is the oil pressure sensor place
  • 169 Answers
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Posted on Dec 03, 2008
    New Friend:
I have a 12 RESL also, but my problem is a bad alternator and a good engine. I've been looking for an alternator. If you haven't been able to fix your problem, I'd like to work with you.
Posted on Dec 31, 2012
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
Kohlers generators have a few things common in all of thier products. One is the overvaltage circuit on their main control boards. Usually can be fixed. Also if you ever go looking for repairs or think you have an issue, I can save you a lot of time and money.
Company from pa repairs a lot of items down to component level.
Flight systems.
If they find your board is okay they only charge a fee for testing.
If they do find a problem, they will charge a fee cheaper then buying a new board, and issue a warrantee in it too.
You might want to check out their site for troubleshooting, schematics, etc.
Posted on Aug 28, 2009
The same thing happened to me me last night. Got a UU error code. Air temperature was 15 degrees below zero in upstate New York. This morning we took a propane "tornado" commercial space heater, opened up the generator housing and directed the heat inside. Apparently there is a great deal of moisture in LP gas lines and this froze in the carburetor. The heater took care of it. We had to speak to many friends until we got this fix. Going to buy this for my generator: Kohler - GM39564-KP1 - Carb. Choke Heater for 12 RESL
Best of luck!
Posted on Jan 17, 2009
    President:
  • 1,450 Answers
Uu is for undervoltage this means that generator is being overpowered
Shutdown occurs if the voltage falls below 80% of the voltage
regulator setpoint for more than 1 second. This protective
becomes active 30 seconds after engine start
could be a wiring fault
also be sure to have a large enough supply line
Posted on Oct 09, 2008
  • TripleTauto
    TripleTauto Oct 09, 2008
    could be a defective regulator
    Sergeant:
    Champion:
  • 334 Answers
Digital Spark Advance Module (DSAM cheak into this test yours
  • nick helpap
    nick helpap Oct 09, 2008
    The Kohler generator unit was preset at the factory and needed almost no adjusting. Out of the box it produced 120 volts on one phase, 123 volts on the other phase, and a rock solid 60 Hz. I had to bump up the voltage by 3 volts to match the load - and that was it.
    I carefully read over the warranty info again and it turns out that Kohler cannot deny me warranty service if someone other than an authorized dealer/distributor performs that startup function
    Genius:
  • 1,847 Answers
Download the file from this link it will help....
http://www.alpinesurvival.com/kohler_residential_brochure.pdf.
    Scholar:
  • 116 Answers
Try to unplug the device and then again plut it after some 5 minites and reset it.
  • mastermind10 Oct 09, 2008
    toll free number for enquiry
    877-232-0165
    For more information, call toll-free in the U.S. and
    Canada 877-232-0165, or visit us at
    AlpineSurvival.com
SOURCE:
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
I have a 12kw lp gas genwrator that starts and runs for about ten seconds and then shuts down.after maybe 25 tries doing this the generator will stay running and then i try and start it again and it will...
These type of gens have a low oil shutoff. Check the oil. Always have spare spark plugs, a cheap fix. My gen always wanted a new plug every year. Look to see if it has a fuel filter.
Sep 24, 2011 | Generac 13,000 Watt / 13,000 Watt Home...
I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
Kohler lp shuts down
What you need to know is there enough fuel going to the regulator. It should be 7 to 11 inches Water Column. If not your problem may be not enough fuel. That includes when the heater in your house kicks on and what ever gas appliance you may have. Once you verify that you need to figure out if you have the proper pressure coming out of the regular on the inside of the generator. Next I would look at compression of the cylinders. It may need new piston rings.
Dec 13, 2008 | Kohler 12 kW Emergency Power System -...
Kohler 12 kW Emergency Power System - 12RES-L Logo
5,686 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
