Question about Softheat Heating Pad HP218 12 3P
Light is flashing on temperature control of heating pad
  • 2 more comments
  • Laura Jan 07, 2012
    It does have auto shut off, and after two hours the off button, which is red, flashes. The light that starts flashing now, is green...the one that indicates the highest setting. When I do press the off button, that doesn't stop it. It just keeps flashing green until I unplug it.
  • Jeremiah Peterson
    Jeremiah Peterson Jan 08, 2012
    The green light is to show that it is at max temperature. It's like a stove top, once it gets hot you can turn it off but it's still giving off heat . It's an indicator. It just shows that once you shut it off there's still heat coming from it. Give it awhile the light will shut off after it cools down.
  • Laura Jan 08, 2012
    OK...thanks for your help, but the heating pad is not hot at all when the light is flashing. There are FOUR temperature settings. ALL are GREEN. I've had this heating pad over 2 years and this has never happened. I think I'm going to just toss it and get a new one.
  •  jon anderson
    jon anderson Apr 02, 2017
    Some pads/blnkets have an 'auto shut-off' after a period of time, eg: 10 hours ... Unplug the device to let it 'reset' it's timer might fix it..
    New Friend:
Mine was doing the same thing! But I fixed it by holding the button and plugging it in at the same time! It worked just fine for me! It might work for y'all! (:
Posted on Oct 06, 2014
  • 9 more comments
  • Dianna Greer
    Dianna Greer Dec 19, 2014
    It worked for me.
  • Quintin Bridges Jan 25, 2015
    That don't work.....stop lying.
  • chippy Apr 04, 2015
    Thanks!!!! Worked for me:)
  • Aimee Schwab
    Aimee Schwab Apr 17, 2015
    Me too!!! Thank you for posting. It had been flashing red for two days!
  • Carla Kinley-Davis
    Carla Kinley-Davis Jul 24, 2015
    It appeared to work, but then automatically he green light started blinking again. I tried holding the shut off button down then plugging in and also holding the temperature button down then plugging in. Like I said, it appeared to work...
  • Amy Robertson
    Amy Robertson Oct 03, 2015
    This worked for me just now! Thank you for the suggestion. This thing has been going strong for 2 or 3 years now :) Even used it to keep little baby kittens warm and washed and dried it and still going..LOVE IT!
  • Mindy
    Mindy Jan 05, 2016
    Thanks Kierra! Mine now works!
  • Amanda Stoots
    Amanda Stoots Nov 27, 2016
    Thank you ...this worked like a charm. My heating pad is working again!
  • Donna Boyd
    Donna Boyd Dec 20, 2016
    Having the same problems. My husband and I both have one and they have both stopped working. I've tried all the suggestions and non worked.
  • Alyssa Mar 13, 2019
    Thanks it fixed mine!!!!
  • Anonymous Mar 29, 2019
    do not plug it into the wall, but be sure the cord is plugged into the heating pad. Now, hold down the lowest setting and don't let it up. Last, plug it into the wall. This reset mine.
Trust me! This thing is a piece of ****! I bought one and loved the heat options that I bought three more for my wife and two daughters and their families. The next day mine went out. Took it to Walmart and traded it for another. Still pretty happy, figured I got a bad one. Three months later not a single one is working all have blinking green lights and won't allow you to do ANYTHING but unplug it! Five and all died the exact same death. Go to Walmart and each time they act surprised! NO WAY!!! This is a chronic problem with this product. I'm contacting the company tomorrow and am going to demand an ecplaination as to why they have not take this item off the market!
Posted on Jul 19, 2012
  • 5 more comments
  • Linda Von Jul 24, 2012
    This is also happening to me. I've had my Soft Heat heating pad less than a year. The green light is blinking on the highest setting. I have tried unplugging it for over 30 seconds and hitting the lowest setting. It stays on the lowest setting for about a minute or two then starts the blinking green light on the highest setting.
  • Prettybrowneyez Msdya
    Prettybrowneyez Msdya Sep 21, 2012
    Did anyone ever find out how to make the light go out? I unplugged it for 2days and when I plugged it back in it was still blinking green
  • gumnecker
    gumnecker Nov 03, 2012
    well mine has been blinking for a week Its only 3 months old I'm glad I check out this site I'll never buy sunbeam again , Ive done all these thnks (unplugging) and still broke
  • Amy Werthwein
    Amy Werthwein Mar 14, 2014
    mine keeps blinking red not green so im guessing it has the same problem as if it was blinking green because mine stopped working as well !!
  • Pamela Jean Jun 03, 2015
    Mine won't stop blinking either. I followed the instructions to reset but nothing works. . I've tried two now and they are both TRASH!! Do not but these.
  • Doris Parsley Workman
    Doris Parsley Workman Dec 17, 2016
    My is new to will not work the light flicker what should do about it
  • Nichole Deischer-Pauley
    Mine was doing the same thing! But I fixed it by holding the button and plugging it in at the same time! Like the comment above said too. Thank you so much!!!!
    New Friend:
Unplugging don't always work. I left mine unplugged for 2 weeks still don't work. Contacted Katz and was told to return the product to them at my own expense, my personal information, return code, and make sure I use a tracking system. Katz Consumer Products 800-477-0457 Mon-Fri 7:30-7:00 EST. Good Luck!
Posted on Feb 06, 2013
  • 30 Answers
If you have used the pad for longer than 1-2 hours, (depending on the temperature) the Auto-Off function has been activated. You should be able to reset the pad by unplugging it from the wall for 30 seconds.
Posted on Jan 07, 2012
  • Jack Waggoner
    Jack Waggoner Oct 11, 2014
    thanks, that worked
    New Friend:
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Posted on Aug 16, 2016
  • 1 more comment
  • Deborah Pack
    Deborah Pack Aug 28, 2016
    My daughters highest setting button (IIII) was flashing. She said it has done this for some time; TODAY (aug 28, 2016) after finding your answer, I unplugged it at both ends, plugged it back to heatpad, then as I held down that "normally flashing button" I plugged it back into the wall & it seems to be working fine. I told her to let me know if it happens again. will update if it does, as I will be trying the method you suggest, but adding in the pressing of the power button etc
  • Deborah Pack
    Well 30 minutes into the test, it went back to flashing. Trying again with pressing the power button also
  • Jack Doe
    Jack Doe Feb 10, 2018
    Worked!!!! Ty, it's a p.o.s. unit, but I'll deal with it until I buy a new one. Your post saved my pad!!
    New Friend:
Well I faced the flashing red light issue and I search alot on Internet but found no proper solution for this problem . So I tried it my way and now it's working . Let me tell u all unplugging is not a solution what I did is I press and hold the power button and then plugged my heating pad Oh yeah! that's right it worked, it's back to normal ane heating good . I hope this will help you guys . Thanks me later ;)
Posted on Jun 21, 2016
  • Julie Lemmon
    Julie Lemmon Oct 21, 2016
    Thank you for the hint. I followed your instructions and now my heating pad works again!!
  • Cheryl-Ann Abernathy
    Cheryl-Ann Abernathy Dec 20, 2016
    This worked for too, thanks.
I tossed mine in the trash and bought a different brand. That one works great
Posted on Jul 29, 2014
    New Friend:
I tried what Dani said and it worked like a charm! I still had the tie wrap around the cord so I removed it and straightened out the cord. Plugged it in and voila! I love this heating pad :)
Posted on Feb 27, 2016
    New Friend:
I'm an electronics tech by trade and have done maintenance and repair work my whole adult life. I'm 50. I just fixed my wife's heating pad. We had the flashing light that wouldn't reset.
If you have to move the cord at all or flatten it out to make it work that means you have a fatigued wire that has broken and is no longer making good contact. Where the cord flexes the most is where the break is most likely to be. It is most likely right after the strain relief portion of the pad connector plug.
After unplugging from both the pad and the wall, you have to open up the controller and then, using an ohmmeter, check the continuity of the wires from the controller to the connector plug that goes to the pad. These are the ones that get moved around the most and are most likely to break.
Using the ohmmeter, I discoved that one of the wires had no continuity between the controller and the connector plug. After I figured out which wire, I then checked continuity from the pad connector plug to the wire buy pressing one of the meter leads through the insulation and into the wire. I then cut out the bad portion of the wire, resoldered it together and used 2 layers of heat shrink tubing as an insulator to protect the open wire. You can get the tubing a radio shack or harbor freight.
Posted on Mar 17, 2017
  • Michelle Hull
    Michelle Hull May 27, 2018
    John, thank you for this explanation. I've got about a dozen heating pads that no longer work & all have similar issues. I'll dig out my multimeter & do some investigation & repair.
    New Friend:
I got one for xmas last year it then start that flash red light at the began of dec i broken my back in two stop so my daughter know how much i use my so she brought my a new at the began of jan and it doing the same thing i will nt have other one
Posted on Jan 21, 2015
  • Gramma Terri
    Gramma Terri Mar 13, 2016
    Mine also did this. I unplugged it from the outlet and unplugged the cord where in connects to the pad. Straightened out the cord, plugged it in and it works.
    New Friend:
  • 3 Answers
Had mine for about a year now tonight it finally died when auto shutting off kicked on it went to a red blinking light unplugged it and set it aside to cool off 7 hours later when I plug it back in I still get a red blinking light. Over all tho it served well for the price not to broken up about it dying after a year
Posted on Nov 01, 2014
    New Friend:
I know how to fix it!! Not only do you have to unplug it for 30 seconds but you have to straighten/flatten your cord out again. If it's all twisted and mangled then it will blink because it's creating hotspots. Then just plug it back in and it won't blink :) Problem solved no reason to return it, because it's not broken.
Posted on Feb 04, 2016
  • 1 more comment
  • Karene Feb 20, 2016
    THANK YOU SOOOOO MUCH!! Your trick fixed mine perfectly!!! Thank you for taking the time to share with us
  • Gramma Terri
    Thank you. I unplugged my cord from the outlet as well as the pad, straightened it then plugged both ends in. Its working!
  • George Vega
    George Vega Mar 01, 2017
    This was exactly it. Thank YOU
    New Friend:
I used mine to sleep on. (I'm too poor for a heating blanket and don't have a heater). Honestly I have good experience. It lasted me almost two whole years with me keeping it on all night every night all winter and rolling all over it. Now the light has been flashing since last night. But since my last several heating pads (different brands) literally melted, I assume that light is because it overheated or got damaged. It happens..
Posted on Oct 27, 2017
    New Friend:
Had ours for 3 years now it is toast
Took the whole controller apart needs new circuit board parts not worth the time and money will get a new one.
Posted on Apr 20, 2016
    New Friend:
Mine did the same thing, top red light blinking and no heat. I unplugged BOTH ends of the cord, from the outlet and the pad itself. Straightened out the cord then plugged it in-working perfectly! I'm so glad I checked this site, I almost threw it away.
Posted on Mar 13, 2016
    New Friend:
I bought mine and the day I opened it it didn't work. It'll occasionally work but half the time it just gives me that red flashing light.
Posted on Apr 26, 2015
    New Friend:
Mine has been blinking for about 30 minutes I have unplugged it and plugged it back in both sides I don't know how many times! Unplugged it and plugged it up at a different outlet and yay it's working!! That was odd I know. I'm just glad it's working again!! My back is killing me and it's almost midnight. Too late to leave for Walmart!
Posted on Apr 24, 2015
    New Friend:
I've had mine for 2 yrs. still working great. Sorry y'all got bad ones. I love mine. Well worth the $20
SOURCE:
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
G 2582 scvi
make this test and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
IF THE MACHINE START IT SHOWS FLASH AFTER 2min
test this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 22, 2013 | Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
G1022
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jun 13, 2013 | Miele Dishwashers
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
Selection Buttons on GE Cafe Dishwasher
Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Jan 12, 2010 | Kitchen Appliances - Others
Softheat Heating Pad HP218 12 3P Logo
35,322 people viewed this question
Top Softheat Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Softheat Health and Beauty Expert? Answer questions, earn points and help others
