When you say it goes up and down by itself, what is the neon doing on the front panel. Is this switching off and on in relation to the oven heating and cooling? If it is, then it could be the thermostat sensor is dirty/covered in grease etc and giving false readings and will need a carful clean. With a fan oven, the fan should keep running, it is the element that the thermostat controls. If the neon stays on but the temperature varies, it could be a fault with the wiring. Does the fan keep running?
If this is the design that the oven will click to light they generally will preheat but shut down once they go to standard bake. The oven will try three times to relight but then shuts down and will not try to light again until you reset the oven. If this is the case the oven burner itself is usually the problem. the burner comes with the electrode.
The heating elements on any stove vary in resistance as they heat up and cool down. When cold, the elements offer more resistance thus less current flows. As the coil gets hotter, the resistance drops and greater current flow develops. The thermostat cycles the elements on and off to maintain the temperature measured in the oven, thus the cycling of power used.
So are you saying that the oven does not start at all?The 350 just appears on the display and then pressing enter it disappears?Does it warm at all?If it warms,it is most likely the thermocouple or ASM,both are the same,just varies between makers.If it does not heat at all,it sounds like somehow the temperature setting got switched from F to C somehow,which can happen completely not done by you.Let me know which situation you have and I'll figure it out.Greg
very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
you guys should check your tempurature sensor. Our oven has been acting weird like saying it has heated up to 400 degrees in like 1 minute haha. Well after a few months of this happening on occasion we get an F2 error flashing..
did some research on it and apparently for GE ovens this is a temp sensor gone bad. Im looking to buy one now which is how i found this post, i just thought id tell you all what i found out and maybe you should look into that as well.
