I had the same peoblem you 1.remove the 6 screws 3 on eacb side 2.remove back panel 3.remove the tip over switch attached to bottem right looks like a black plugin4.hook the 2 wires that was connecting saftey swith togetber and tape them together with electrical tape (making sure they are touching obviously)5. Reassamble and your good to go no more constant relighting
SOURCE: what size propane tank do i need with a Mr. Heater
Rule of thumb is that you have 100,000 btu's per gallon of propane. This only translates into the length of time you have available in a tank of gas. The problem arises when you consume too much too fast. The gas can't produce enough vapor to continuously run and becomes dormant which is commonly known as "freezing up". You can use a typical (20 lb.)5 gallon propane tank (barbacue size), but it will more than likely freeze up in 2 - 3 hours of continous use. I'd suggest going to the next larger size a 30 lb. or 7.5 gallon size. The best way to work this system is to have two 5 gal. tanks so you can switch one out when it freezes and let it thaw while your using the spare.
Testimonial: "Thanks very much for the help!"
