It show me this error message American Megatrends Press DEL to run Setup Press for BBS POPUP DDR Frequency 400 Mhz Checking NVRAM 512MB OK USB Device(s) : 1 Mouse Auto-Detecting Pri Master...IDE Hard Disk Auto-Detecting Pri Slave...Not Detected Auto-Detecting Sec Master...ATAPI CD-ROM Pri Master: WDC WD1200JB-00EVA0 15.)5R15 Ultra DMG Mode-5, S.M.A.R.T. Capable and Status BAD Sec Master: HL-DT-STDVDRRW GWA-4161B 1.00 Ultra DMA Mode-2 Auto-Detecing USB Mass Storage Devices . . 00 USB mass storage devices found and configured. Pri Master Hard Disk:S.M.A.R.T. Status BAD, Backup and Replace. Press F1 to Resume.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty even something as small as an electrical extension or a faulty fan lead can cause this problem a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working make sure the CPU central processing unit has thermal paste and dust free and is securely seated make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
hope this helps you
http://www.home-computer-support.org/american-megatrends-bios-update.html
hope this helps
