You could have a problem with the transmission/gear box.
it is the main mechanical device that is being driven by the motor to convert the rotating motor to the agitating action of the agitator.
you may need to replace the whole gear box.
tnx 4 using fixya,
drcool
hi tom,
i guess a cheap fix would be to go to a salvage yard and get a used gear box to replaced your old one, or if it is still expensive, try to open the gear case and just replace worn out gears that you can find.
tnx again,
drcool
ok tom, its up to you,
can i just make a request, the rating is just as important to us as answering your questions, a helpful rate could still deduct 0.01 points from my rating since i got an 87 already. can i request for a fixya to boost my rating further?
i will greatly appreciate it.
tnx in advance, have a nice day.
drcool
I hope this is not the problem, but I suspect you are right. Is it worth replacing the gear box or do I need a new washer? I'm broke right now so any quick fix will sure help us out.
Tom
Thanks, drcool. I appreciate your quick and direct responses. I've decided to "let go and let God" right now and see what happens. Tom
