ASUS A52F-XE2 Notebook Logo
Posted on Jan 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which button do i press to get into the boot menu of the asus a54f
Justin
Level 3:
  • ASUS Master 2,072 Answers
  • Posted on Jan 27, 2012
Justin
ASUS Master
Level 3:
Answers
2072
Questions
0
Helped
431934
Points
5629
Common keys for boot menu, BIOS and/or recovery are F1,F2 F9-F12 or del. It should list which is for what on your specific computer as it boots. Boot Menu is usually F9 or F10
Downloaded Windows 10. Why is pc screen stuck on aotio setup?
Hi there, please try these steps and see if it resolves your issue.
  1. Select the Boot menu in the Aptio setup utility, select 'Launch CSM' and change to enable.
  2. Select the Security menu n the Aptio setup utility, select 'secure Boot Control' and change to disable.
  3. Select Save & Exit and press 'yes'.
  4. Hold down the power button until the unit switches power off completely.
  5. Switch back on and continually press the F9 button for about ten seconds; this should now allow the unit to boot up into the Windows Recovery menu.
  6. Select 'Advanced Start Up' and wait until the recovery menu appears.
  7. Select ' Advanced Options'.
  8. Select 'System Restore' and select a date prior to when the problem occurred.
This is for an Asus laptop but even of you are not using an Asus the troubleshooting should be the same. Courtesy of Microsoft customer support. Asus Laptop Stuck in Aptio Setup Utility
2answers
Why is my laptop comming up with aptio setup utillity
Try this
1/ Select the Boot menu in the Aptio setup utility, select 'Launch CSM' and change to enable
2/ Select the Security menu n the Aptio setup utility, select 'secureicon1.png Boot Control' and change to disable
3/ Select Saveicon1.png & Exit and press 'yes'
4/ Hold down the powericon1.png button until the unit switches power off completely
5/ Switch back on and continually press the F9 button for about ten seconds; this should now allow the unit to boot up into the Windows Recovery menu
6/ Select 'Advanced Start Up' and wait until the recovery menu appears
7/ Select ' Advanced Options'
8/ Select 'System Restore' and select a date prior to when the problem occured
System Restore worked perfectly for me; good luck
Find boot menu button on aus k50ij
you can enter the bootmeny by pressing F8 at boot up, or enter bios by pressing F2 at boot up.
Del enter setup or f12 boot menu
try reseating the graphics card (remove and reinstall) making sure to press it firmly into the slot
How to enter bios asus on my asus v550c
On systems with Windows 8 pre-installed, you can access the UEFI (BIOS) setup screens from the Windows 8 boot menu:
  1. Press the Windows key + C, or swipe in from the right edge of the screen to open your Charms.
  2. Click Settings.
  3. Click Change PC Settings.
  4. In PC Settings, select General.
  5. Under Advanced startup, click Restart now. The system will restart and show the Windows 8 boot menu.
  6. In the boot menu, select Troubleshoot.
  7. In the Troubleshoot menu, select Advanced options.
  8. In the Advanced options menu, select UEFI Firmware Settings.
  9. Click Restart to restart the system and enter UEFI (BIOS).
How to access BIOS on an ASUS laptop
How to launch the boot menu on asus p5ld2-vm ?
Hi, you can download a manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5LD2VM/#download
Please select your windows version.
Select manual and click on global for download.
Unzip the file before you can read it.
Press the delete button when it boots to enter the bios.
The rest you can read in the manual.
2answers
How to reformat an assus cg5275 wich key do i use to starty reformat
Usually f9 with assus
let me know if that worked best of luck
I have an asus 1000he netbook and haveing boot problems what is the boot menu key?
ESC (Escape) on the keyboard should be the Boot Menu key, means you have to tap the ESC key once you press the power button to switch on the Machine and select the boot device from the options available.
If ESC key doesn't work, then try F2 or F8 or F12 (these are all the boot menu keys for Asus motherboards and Laptops).
Let me know if you need further help, but with more details about your problem.
Good Luck.
Thanks.
Asus m2v won't boot
Press delete to go to setup. In the boot menu tab of the BIOS make sure the correct boot disk is selected, and that hard disk boot has first priority. Also make sure there aren't any bootable disks in the cd/dvd drives that might prevent the computer from booting.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
