Canon Pixma MP500 All-In-One InkJet Printer Logo
Posted on Oct 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vertical black line running length of the paper
The first few printed pages of the day have a 1/4 inch thick vertical black line running the entire length of the middle of the back of each page. As printing progresses, the line fades. I've tried performing all the prescribed maintenance tasks (cleaning roller blades, bottom plate, etc. - even tried Q-Tips to wipe ink off the protrusions) with no improvement.
Thanks in advance for your help!
  • 10 more comments
  • nutmeg05324 Oct 08, 2008
    :( I have the same problem. I was trying to print the addresses on my wedding invitation envelopes and that black line showed all the way down the back of my envelopes.
  • laserlite51 Oct 13, 2008
    I have the same problem. Were you able to find a solution? It seems there is a piece of foam in the middle under the PH and it may absorb ink and then comes out on the back of the page. I suspect the machine would have to be completely taken apart to replace the foam if it is available.
  • Anonymous Oct 14, 2008
    I work in the IT department of a big firm and I have seen this problem twice last week with Canon ip4000 printers. It's really odd and we simply replace the things with ip4500 printers. Don't know if they still cause the same problem.
  • jtwelch Oct 17, 2008
    I have a Canon PIXMA iP5200 printer that has started to output a 1/4-inch vertical black bar down the back of each page. I tried to use the Canon fix for cleaning this problem, but it did not work.
  • factfinder Oct 21, 2008
    The black line appears even when you copy, so it is not computer-related. I contacted Canon, and was told to bring the printer into an authorized repair shop. Unfortunately, it's an hour drive, so I'm not sure it's worth it.
  • Anonymous Nov 02, 2008
    I have a Cannon ip4200 and have started to have a thick vertical black line on my copies.
  • kars Nov 10, 2008
    same problem, a 1/4" solid black line down the backside of all printed material. performed all the maintence steps and could not correct the problem. i'm finished with canon products and will return to hp printers and nikon cameras.
  • slemaster Nov 21, 2008
    Same problem - it has even spit ink on user at times, so she setup a "shield" at the output tray. I replaced her's with an HP. Don't know if repair at $90 would be worth it. I'll look into finding a repair manual and take apart on my own time for kicks and giggles, and who knows, maybe get a little more life out of it - unless it starts spitting a me!
  • Anonymous Nov 25, 2008
    i have a canon mp530 and it started to giving a thick black line of ink down the back of the page on every doc that comes out of the printer or copier. i have tried all the remedies but nothing helps. it started hapening a week after the warranty ended. so i will not be buying another canon printer.
  • Anonymous Apr 08, 2009
    Same thing, same printer- black solid line down the back of anything I print for the first few copies. Very frustrating.
  • laserlite51 May 11, 2010
    This line appears even when you copy. It has nothing to do with the computer.
  • Troy Staley
    Troy Staley Jan 13, 2018
    sounds like ink on the rollers..
A
Anonymous
I have a PIXMA iP5200 with the vertical black ink smear problem down the back of the paper. I called the local Canon printer repair facility, and a serviceman said that the black line is caused by too much ink in the ink absorber device below the paper path. He said to fix it would cost $60 to $90 because it requires disassembling part of the printer, replacing the absorber foam, installing a longer tip for the excess ink, and reassembling and testing the printer. I asked if this would be a permanent fix. He said no, that the problem could reoccur.
Given the cost of repair and the age of the printer (over 3 years), I decided today to buy a Canon MX850 All-in-One printer at the local Staples, which cost me $169 after a $30 mail-in rebate from Canon. The MX850 uses the same printer cartridges as the iP5200 and offers lots more features
Except for the recent printing problem, I got excellent results and service from the iP5200 over the time I used it.
Jim
Portland, OR
  • Troy Staley
    hey jim, i'm in eugene and have a couple hundred canon printers. even some ip5200's i believe. look for Hvytoys booth on bonanza and get in touch. i can get you another one if you want, or about any other canon printer of that era.
Anonymous
Level 2:
Sergeant:
  • Expert 352 Answers
  • Posted on Oct 21, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
352
Questions
0
Helped
85870
Points
809
Hi all, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Thin vertical line on copies
Tara, if the ink levels are ok, try clean and allignment functions from the tool menu. Use CLEAN UNUSED PAPER.
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
Black Vertical Line on the paper
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine;quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. if the issue is there at that point then it would point to the cartridge. if not then the fuser
Let me know....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
old marine
old marine
ZJ Limited
ZJ Limited
