Sylvania LD320SSX LCD TV Logo
Anonymous Posted on Mar 04, 2017
UL50VT wont Connect HDMI to Sylvania LD320SSX .. No screen..
Hello, I seem to be having an issue i cant figure out. I have an Asus UL50VT laptop with the GeForce G210m video card drivers are up to date and Im tryign to connect it via HDMI to my Funai/Sylvania LD320ssx 32" HDTV(with updated firmware). the problem IM having is if my TV is turned onto a normal "Cable" channel my computer can see it and registers the display as "Sylvania" under my multiple monitors section of NVidia control panel but the moment i turn the channel to HDMI 1 OR 2 on tv the display name goes away and I can do nothing to it cant resize or anything now Ive somehow got it to work once or twice by plugging and unplugging the HDMI cable and have tried swapping it out with 6 differant cables yet I cant get it to maintain a display .. Im really at end of my rope here... i read read and read online but cant seem to find anyone that seems to be having same problem as me Ive tried all the settings that I can without success so if anyone has an idea PLEASE SUGGEST and I have recently recovered my laptop to factor Windows 7 Home to see if that was issue and wasnt and upgraded to WIN 7 Ultimate and nothings helped...
  • Anonymous Jan 07, 2012
    I really dont see how programming a remote I dont have or use or need is going to solve the problem... this is a connection issue between laptop and a hdtv used as a monitor/display....
2 Related Answers
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Sep 23, 2009
SOURCE: I need the code to program my comcast remote for
Because each code is not unique and diffrent remotes have diffrent codes for the sae TV I would call comcast and have them send you out the remte manual. You did not tell me witch cable box you where using too so its hard to tell what remote your using.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
  • 5 Answers
  • Posted on Nov 30, 2009
SOURCE: I can't get any of 3 universal remotes to work
Try 1864. It worked on my Media-Com remote when none of the other codes worked.
Reset button asus laptop
If you are referring to the System Restore/Recovery procedure, you can find the info in the User Manual: http://www.asus.com/Notebooks_Ultrabooks/UL50Vt/#support_Download
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Screen only flashes colors, no controls function
remove power from the set and any box being used with it, after a while power both back up, a box or the set can cause this issue.
Blue red and green screen
I too have this problem and am unable to find a solution. Someone please post a fix for this issue if possible??????
I have a sylvania model LD320ssx. How do I eject the dvd if I don't have a remote?
Unless it has an eject button on the unit you need the original remote.
Blurry picture sylvania ld320ssx LCD TV when connected to ps3
Must change the Signal Tuner board.U well have good video after that.Not than 100% ur LCD Black projection Screen is dead not worth repairing.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
