I would advice you to stay away from SteelSeries 7H Headset. I have had to replace them 2 times with about 1-2 month apart because of the right speaker stopped working. It's a wiring issue and it's very common. The support told me they had fixed the issue but that was a plain lie. I'm on the 3rd headset now and have gotten the same issue again. And to put more salt in the wound I had to pay for the shipment of the headset to their factory both times ! No, they will not repay me the money, i did ask about it. The headset have good sound but the wiring problem and steelseries really bad and really cheap support isn't worth buying the headset at all.
I just dealt with one of these last month, its a ten minute fix if you have a soldering iron. The wire gets strained inside, they didn't allow enough slack in the wire for the movement of the earpieces. A quick resolder of the broken connection and a dab of hot glue to keep it from moving was all it took. Cost of repair was zero.
SOURCE: is the steelseries 7h usb
Hello Sixlittledev,
Although the 7H USB headset is not natively supported by PS3, you may be able to get it to work if you have a headphone jack in your TV.
You will need to connect the headset in the following manner:
Headset microphone cable -> USB card -> PS3
Headset audio cable -> 3.5mm extension cable -> TV headphone jack
Although we do not guarantee compatibility and this method is a bit cumbersome, you can get it to work this way.
Mike S
SteelSeries Support
Http://www.steelseries.com/support
