I tunred on the sound in the bios and booted the pc, but got no sound even with buying new speakers for it so i brought a sound blaster live model ct4830 PCI, and download the driver for it but still no sound can anyone help its driving me nuts as i cannot find a soloution for it, my is pm800-m2 pentium 4 2.4ghz
I would check and see if this is not ticked on "MUTE" in your AUDIO PROPERTIES.
Hope this helps.
Regards.
Let's try the obvious - then move on to a more in-depth fix for this.
Assuming you're running Windows ..
Lower right corner of the screen (in the task bar) is a speaker icon. If there's a red circle lined through, it means the audio is muted or turned off. Simply click on the icon, and the pop-up will show the same circle. Click on that, and it ought to work. Again, this is the obvious, and most common I've found to occur.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/keith_f374b1cfd1696a17
SOURCE: drivers sound blaster live ct4830 for windows xp
Google it or check it here: //http://drivers.softpedia.com/get/SOUND-CARD/CREATIVE/Creative-Sound-Blaster-Live-CT4830-Driver-51201383-WHQL.shtml
SOURCE: we didn't find creative labs sound blaster model:
http://support.creative.com/Products/ProductDetails.aspx?catID=1&subCatID=206&prodID=4856&prodName=Sound Blaster Live! Value&subCatName=Live!&CatName=Sound+Blaster, i searched for you, found this link to the drivers, for the 4830..said it is a creative live sound blaster. hope this helps you! good luck.
SOURCE: Searching drivers for Sound blaster live! value CT4830 for Win98
Hi!
Can you post the exact model of the sound card and the your operating system also?
Also, driver and user guides downloads are available via http://support.creative.com/Products/Products.aspx?catid=1
SOURCE: Creative Labs Sound Blaster Live! Value. CT4830.
you will need o load driver vista does not recognize add ons automatically in some cases
