Question about Mitsubishi WS-55819 55" Rear Projection Television
TV does not power on - Mitsubishi WS-55819
Hi, The TV has been working perfectly untill I turned it off last night. But, it does not power on any more.and there is no power LED. There is power running thru the cord. Has not had any problems with convergence. If the fault is within the power circuitry and assuming the fuses are ok, what are the other common problems? Few other queations I have are, can the prower transformer be replaced or does the whole power cicuit board need to be replaced. I have replaced convergence ICs in two WS55859 TVs before for a friend and have a basic knowledge of electronics as a hobbyist. Any help is appreciated. Thanks.
    Top Expert:
  • Mitsubishi Master
  • 76,125 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 12, 2017
4 Suggested Answers
SOURCE:
  • 39 Answers
SOURCE: Mitsubishi WS 55819 with a convergence
CEM-NO, BOTH ICS' WORK ALL 3 CRT YOKES.YOU EITHER NEED TO REALIGN THE RED IN FACTORY CONVERGENCE MODE OR YOU HAVE A RESISTOR THAT HAS FAILED.THE LATTER YOU MAY ACTUALLY BE ABLE TO SEE IF YOU LOOK CLOSELY.OH, ALWAYS DOUBLE CK. YOUR SOLDER CONNCETIONS.GOOD LUCK. JOE TV
Posted on Nov 29, 2007
ctf1800
  • 4402 Answers
SOURCE: mitsubishi ws 55819
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Posted on Jan 16, 2008
SD Tech
  • 14553 Answers
SOURCE: Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Posted on Oct 28, 2009
Testimonial: "Helped narrow down where the problem is."
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
I need a power supply for a Mitsubishi Medallion WS-55819
did you try contacting the Mitsubishi service center for the part?
Oct 22, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 TV Wont turn on.
code stands for loss of vertical. I had one of these if you can check pico fuses, check the ones on the main power board the one with the 2 convergence amps if any of them are blown then most likely the convergence amps have shorted out.
Aug 10, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 Power Loss error message. Help needed please
Sounds like a problem with the standby power supplies is losing the standby which acts as if the TV had been unplugged. I would check the stand by power supplies
Jun 23, 2009 | Televison & Video
Mitsubishi WS-55819 power issue
No, that'll do it. Once you've changed em you'll know right away if somethin isn't right. But take faith and fire that puppy up. If the pix is good you did good. If something is amiss. I'd be happy to walk you through it. My money is on you though.
May 27, 2009 | Mitsubishi WS-55819 55" Rear Projection...
My tv ws-55819 tv won't turn on it cliks on but it won' syat on
ok when the power is plugged in hold down the menu + device buttens for five sec what is the error code there should be two sets of numbers....
like 1 pause 2 let me know and i'll see what i can do!
Feb 01, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsibushi WS-55819 power problems
Wade, My dad has this same set and had the same problem -- Sears came out and replaced the power switch.
Sep 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws-55819 power problem
Hello DaveDaveDave, Ok let's levelset as is said in the business world today. it looks like you have an overcurrent protection problem which means that the tv set has a component that is causing excessive current to be drawn. Now this can be caused by a component withc has become "leaky" (by leaky this means the inability to prevent the flow of electrons as related to dc voltage). Your last statement is the reason I am replying how I am. Since you don't have equipment your only option is to take this set to a TV repair shop and have it repaired. I have given you a possible cause a component in the HV section that may have gone bad, but without substantial data as to the voltage levels and signal appearances, one can only guess. I hope this helps and you find what you are looking for. Thank you, Shuttle83
Aug 12, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
154 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
