Question about Sony KV-35S42 35" TV
No video or audio - Sony KV-35S42 35" TV
  • Sony Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Jan 06, 2012
SOURCE:
Wiring color code for lcd screen
AV VIDEO CABLEYellow- Video Red- Right sound R White- Left Sound L
Component Cables RED ORANGE- video BLUE- video GREEN-video RED- audio R WHITE-audio L
HDMI provides both video and audio all in one.
Optical out Audio Audio format to surround sound. Better sound quakl
Hope this helps
Jul 20, 2011 | Televison & Video
Tip
HD to audio ? Convert HD to audio to extract audio from HD videos on Mac
Some users may want to extract audios from their HD videos. Their HD videos may be either from HD movies or HD videos clips taken by themselves, and these HD videos have good background music or sound that they want to extract and save in MP3, AAC or other audio formats.
If you are running Mas OS and want to convert HD to audio, Doremisoft
Mac HD Video Converter will be the perfect choice because this application works perfectly to convert HD to MP3 and HD to other audio formats with excellent quality. To convert HD to audio on Mac, you can just follow the steps below:
Step 1: Import HD video to Mac HD Video Converter
Click the "Add File" button to add the HD videos you want to convert to iTunes
Step 2: Select an audio format to convert HD to audio
Click to open the "Profile" drop-up list, move your mouse pointer to "Common Audio", and you will see all the preset HD formats from the right menu. Click on the format you prefer to select it.
You can find that most common audio formats are available here, so you can convert HD to MP3, HD to AAC and HD to XX and so on.
Tip 1: Tick the "Apply to all" button to apply the selected audio format to all the added HD files.
Step3: Convert HD to audio
Click on the Start button on the lower right corner of the main interface to start converting HD videos to audio.
After the conversion, the folder where the extracted audio formats are saved will be opened,a nd then you can put them into your audio players to enjoy your favorite movie music!
Click here to see detailed info of Doremisoft HD Video Converter for Mac
on Jul 30, 2010 | Microwave Ovens
Video is not playing with audio
the bit rate of audio is high thats why audio not support while playing video, use normal bit rate video or audio , u can convert your fav video and audio through your pc
Apr 11, 2010 | Samsung Star GT-S5233 Cell Phone
Audio no video with vivitar 850 w
Google a program called
Video Download Studio
then you can use it FREE download video or audio form YouTube, google, metacafe, redtube, dailymotion etc. attention: download function is no need to register
you can also use it to convert video to audio, video to video, audio to audio.
use it convert video to mp3 mp4 for your iPod
tutorial;
http://www.downloadvideos-convert.com/how-to-use
Jan 05, 2010 | Vivitar DVR 850W Flash Media Camcorder
Can i record a video using audio in from my computer? i want to record video and use existing audio
There are two possible solutions for you as follows:
1. swapping video and audio connectorsis not possible. The connectors may look the same but the video connector wil not accept audio and the audio connector will not accept video( video is normally coloured yellow and audio is coloured red and white for two audio channels)
2. however if you are trying to superimpose video to audio that is already on the timeline in the computer this is possible. however you need to be conversant with the type of editing software that you are using
Oct 26, 2009 | Video Cameras
When viewing downloaded movie I have audio but no video in media
tutorial;
Mar 17, 2009 | Canon PowerShot A560 Digital Camera
No audio with 1200 webcam
Normal 0 AIM (AOL) Messenger
  1. On the VIM sign-in window click on Edit.
  2. Then click on Settings Enhanced IM.
  3. Next click on Enhanced IM.
  4. Then click on Audio Video.
  5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone Speaker
Camera The audio and camera should function now.
Additional info to use with VIM settings.
Adjust Your Audio and Video Settings: In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
  • The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
  • images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Oct 13, 2008 | Labtec Logitech 1200 Webcam
Sony KV-35S42 35" TV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
