SOURCE: no heat
hi there
your problem is either the t-stats have blown which is very common or your heater is blown..
im guessin your t-stats beacuse they are the most common on hotpoint dryers to blow. There always blowing
They located at the back of the dryer behind the protuding panel so there for you dont need to open it all up just that panel.
To check if their blown check for continuity,, no continuity no good merry christmas cheers
SOURCE: HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
SOURCE: GE Electric Dryer Heats up but does not automatically turn off
Change the sensor in the drum. Theres a sensor that tells it if there is moister in the enclosure.
SOURCE: Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
SOURCE: GE Profile Harmony DPGT750EC Electric Dryer not heating up
Check the air flow from the vent-if there is no air or very weak air flow, it is the blower motor. It is not getting up to speed or not spinning at all. Try this:
Press "Home"
Press "Help"
Simultaneously press and hold down BOTH
"My Cycles" and "Back"
After a few seconds the dryer will enter service mode and report any problems.
Pertains to GE Profile HarmonyDPGT750EC/GC
