La Crosse LaCrosse Technology Wireless Weather Station Logo
arthur koszoru Posted on Jan 05, 2012
Outside transmitter not working - La Crosse LaCrosse Technology Wireless Weather Station
1helpful
Carlon plug-in Wireless Chime I have a Carlon wireless Chime with transmitter from Thomas & Betts model 3301T and wall receiver RC3130R. It works inside the house and inside the front door , but not...
What happens if you go to the side of the house right by a window (non-metallic screen, or at an unscreened part of the window)? If it works through the window, you probably have steel mesh behind the brick that is shielding out the transmitter signal. The steel door frame isn't so great either. However, if you have a non-metallic door, you can put the transmitter on the door itself. It will seem weird to other people, but if it works ...
Can I get a new outside weather transmitter for 915MHz.
'make model (what it is)' in all question please or we are guessing!
Your Google search query for this is
make model outside transmitter replacement
https://www.google.com/search?q=outside+weather+transmitter+for+915MHz
Unless it is La Crosse, you are unlikely to get spares, but an electronics engineer my be able to repair your.
SS 5010 not sensing outside temperature. I replaced the batteries in the transmitter and pressed the TX. However, the display inside just keeps blinking. I can see the inside temperature.
Inside temp is separate from outside...no connection whatsoever. If the outside transmitter has new power and fails, it may have gotten wet inside and may be rendered useless. Replace with a new outdoor transmitter.
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
3helpful
2answers
Can't get outside temp on my atomic clock
If you still have the instructions read up on pairing the transmitter to the clock. You'll need to do that every time you change batteries on the outside transmitter. If you don't have those instructions , go to the clock's web page to get the manual for your model of clock.
Sep 23, 2014 • Home
2helpful
2answers
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
Sometimes the RF frequency from the outside transmitter loses contact with the clock's frequency ( it has happened to me only twice in 6 years ), and then the outside temp will not show. Simple solution to fix this is: Take down the outside transmitter and the internally mounted clock. Remove batteries from both. Wait about 10 mts. First install batteries in the transmitter, then after about 30 seconds, install batteries in the clock. In about 5 mts, you will find the clock showing the external temp like before.
Is it possible to connect my PC to my outdoor speakers? I want to play music outside using my PC. Is there a special connector that I need?
There are a couple of ways to go about this. The first would be to locate a similar computer speaker system set up outside - provide power and extend the cable to them - if not too far. When you want to listen to the outside speakers, plug the cable into the headphone jack of the computer. Adjust volume and enjoy.
Another way, would be to buy (or build from kit form) a low power FM transmitter. These devices are available in mono & stereo types and will play over all FM radios and stereos in a 50 to 300+ foot radius (depending on antenna, wall construction, transmitter power, etc.) when they are tuned to the transmitter frequency. These can be found for under $100 or built for as little as $30 or so. The upside to this method is that the music is available over ALL radios nearby.
Still another way is a wireless speaker system. This works like the FM transmitter, but will only work on these particular speakers. These will require power only - but some will work from internal batteries as well as AC power. The system includes a small transmitter, power cord & cable to plug into a headphone jack - all for use at the computer, and two speakers - each with a power cord as well and possibly a remote control.
Use of a spare pair of old stereo speakers will probably not work as the computer's sound card rarely develops more than a watt or two - and most home speakers require 10 or more watts to be driven properly.
2helpful
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
7helpful
2answers
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Top La Crosse Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
