I have a Yamaha RV3300 receiver that will not turn on. I can hear a click sound whenever I power on while it was working. I can still hear the same click sound when I hit the on button but can not see anything on the displace. There was no response. I did check the fuse and also took it to RadioShack to verify the fuse. It is still good. What can I do?
Sounds like a relay (there to keep the unit from getting "fried" when there is a malfunction). You need to check that out to get started....
This should help..
https://www.hifiengine.com/hfe_downloads/index.php?yamaha/yamaha_rx-v3300_dsp-az2_service_en.pdf
You'll need to register, but it is free to do so!
Good luck! Login HiFi Engine
SOURCE: tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
SOURCE: Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
SOURCE: When push the power button, I can hear a relay
When the unit functions correctly, you should hear 2 clicks. The first is the power relay that "starts" the unit. The second is the speaker protection relay that will kick in the speaker connection. If you do not hear the second click, the unit is in protect mode. This means that a problem was detected in the amp section and the unit is prevented from connecting the speakers. This is done to prevent further damage. Typically the output transistors fail and cause this. Expect a parts cost in the $25-$50 range for this repair.
Dan
SOURCE: 2006 saturn ion door locks and trunk pop wont work....
The remote won't ework because the problem is in the vehicle. Just for test purposes and possible remedy. Remove and clean the negative battery cable. Ensure a clean , tight connection. Then find the body ground. Yhis ground is locted usually at the top rear of the engine. .I's a snall stainless steel strap bolted to the engine and fire wall, This must olsobe clean with a good contack. Might as well clean the + cable and connection on the battery while you are there. Good luck and keep me posted olease. Good Luck, Ned_
Testimonial: "Thank you for your prompt response I will try that first thing in the morning and let you know!"
SOURCE: Bike will not start. Power to the tach and I hear
if u run a live straight from battery to live on starter moter should turn over telling ustarter motor ok , so problen in wiring hope this helps
The Correct Model Number should be RX-V3300. Sorry
I have a Yamaha RX V3300 receiver that will not turn on. I can hear a click sound whenever I power on while it was working. I can still hear the same click sound when I hit the on button but can not see anything on the LCD panel. There was no response. I did check the fuse and also took it to RadioShack to verify the fuse. It is still good. What can I do?
