I have been suffering mains power spikes for some time (don't ask but it is self induced) and this has resulted in a component destroying its self. Upon inspecting the PCB there is, what i guess was a surge protector, in a charred heap, including the heatshrink protection. The silk screen on the PCB identifies this as TR301 on the top of the board but C309 underneath. It is now a charred pale green but i suspect it may have been blue at some point as it has suffered thermal dammage. Can anyone shed some light on what this component used to be, component manufacturer, ratings, alternate uprated part?
SOURCE: Antec Phantom 500 burned out
u can buy a ps tester on ebay to make sure all rails are ok 5 bucks for it easy to use great tool to have dont have to be bunrt to have bad rail i seen it
SOURCE: Where to replace burnt out PCB.
Unfortunatly I have the same problem but it seems the main MOSFET bolted to the heatsink (SSS4N60B) in the high voltage section has failed which I suspect has led to the destruction of the capacitors. I lost the 5v and 12v supply which happen to have the damaged caps in there circuit. See how you go but I'd be having a close look at that MOSFET as well.
SOURCE: 47 inch vizio blown fuse
i am having the same problem and my power light wont even turn on so i think it might be tht power fuse. Is tht what was wrong with urs?
