Question about DeLonghi DE500 Dehumidifier
My handle fell off my delonghi kettle which cost me nearly 60 pounds i was scolded luckily my 9 month old an my 3 year old was not round my legs at this time or it would of been serious i was surprised by what happened i had not had the kettle more than a year an it was not a cheap kettle an wonder how many other people this has happened to the way it came of was surprisin as it is a kettle the top handle literaly came off when pouring leaving the bottom half attached i dont see how that would pass as safe when it so easily happened like i say could of been serious had my kids got scolded would be very angry how ever i did an it burned for 5 hours like i say luckily it was me an not baby or child .
  • kezzia Oct 07, 2008
    i am makin a complaint should i make a more public complaint as buyers of this kettle should be aware i want to know how it passed safety standards should i talk to tradin standards has your prouduct is not safe an should bne looked at
  • 63 Answers
I would suggest you not use it for the mean time. have it checked by somebody who knows how to put back the handle of the delonghi kettle. if the handle is metal, you can have somebody solder it so you can use it again, if its plastic, then you can gave it glued or screwed in.
Posted on Oct 07, 2008
    Scholar:
  • 116 Answers
Http://www.4delonghi.co.uk/cgi-bin/catalogue.pl?section=256048&path=54536,256033
click this link for what you require.
and take care of your kids.
thanks.
    Genius:
  • 3,422 Answers
You can orders the spares or parts for your model by clicking on the below link:
http://www.4delonghi.co.uk/cgi-bin/home.pl
  • Priya darshan Oct 07, 2008
    If this is still under warranty i suggest you to get it replaced.
    That clearly indicates a manufacturing defect.Please get it replaced if this is still under warranty.
    Sergeant:
  • 268 Answers
Wow....good thing the kids were not around......
Unfortunately I cannot say this has happened to me!
  • Chris Callo
    Chris Callo Oct 07, 2008
    The product you are refering to is not "our" product , we are just a support site :-)
SOURCE:
Delonghi dtc95e
http://www.4domex.co.uk/cgi-bin/search.pl?parts_search=s&brand=Delonghi&model=dtc95e&part=instruction+booklet Instruction book for oven costs pounds sterling. Incorrect listing under 'dehumidifiers'.
Jun 15, 2013 | Dehumidifiers
I have a Delonghi DH250R dehumidifier.It make a clicking noise every now and then when it is turned on. Is it that the thermostat trying to kick in to start the compressor ? And the dehumidifier is not...
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1& 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 06, 2011 | DeLonghi Dehumidifiers
How do u fix errror code E3 delonghi de400
That code indicates a sensor failure and that part to fix it will cost around $200.00
You can darn near buy a new one for that... til you get it and take the time to install it...
heatman101
Nov 25, 2010 | DeLonghi DE400 Dehumidifier
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
My 3-month old Delonghi 50 dehumidifier is leaking
Did you find the solution to your delonghi 50 pint issue? We have similar problem and No Manual - we are looking for manual too, any thoughts on where to find that too, please?
Jul 06, 2009 | DeLonghi DE500P Dehumidifier
Moisture not collected
low on freon is the compressor running?
Jun 18, 2009 | DeLonghi DE400P Dehumidifier
Lost manual I believe the model is DH90 U, it's about 9 years old
Here you go, good luck.
http://www.sylvane.com/images/productpages/DeLonghi/Dehumidifiers/DDH30-DDE40E-DDE50E-DDE65E.pdf
Jun 11, 2009 | DeLonghi DDE50E Dehumidifier
Really thick ice on back of dehumidifier
It is now frozen because the humidistat, which controls the on/off cycle, is starting to age and forgetting to turn off the dehumidifier. Try removing the humidistat and, using compressed air, blow it out thoroughly of any dust. Then spray the rotary control area, including electrical parts, with WD-40. Then, blow dry again with the compressor and try again.
Jun 23, 2007 | DeLonghi DDE50E Dehumidifier
DeLonghi DE500 Dehumidifier Logo
61 people viewed this question
Top DeLonghi Dehumidifiers Experts
nm156
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
