SOURCE: How do i get rid of microphone delay?
You need to adjust the buffer in acids settings. If you set the buffer too low, everything will be in time, but you will get pops and clicks in the audio. Try and find the happy medium for your system. Also be sure there are no other programs such as a virus scanner enabled or running while recording.
Depending on your sound card, there could be another solution if adjusting the buffer does not work for you.
You will then need to find a different ASIO driver that is compatible with your sound card. If you have a soundblaster, there are 3rd party ASIO drivers that you can install, and that should fix the issue.
Good Luck!
