System Crashed!! My system when down a couple weeks ago and I have not been able to get it up and running again. I took it to Radio Shack where I purchased it and the recommendation is that I re-install Vista (Basic). The problem is that the Install disck did not come w/the computer. I cannot restore anything to the "d" drive. All my documents, pictures, etc. are in what the system is saying is a "TEMP" file and all this is beyond my ability to rectify. I would appreciate your advisements. Thanx --Richard
system crashed and i dont have a restore disk. Where can i get a restore disk. for this system. All my pic and college papers are on there what can i do to get this information off the system.
What should i do i have the same problem my system crashed in November also What should i do i have the same problem my system crashed in November also
You can't post conmments that contain an email address.
they sell the product and the warranty that goes with it.
It is not fit for the purpose or use when you went to use it so it is a problem that radio shack does not need so they are obliged to replace it or have it fixed even to keep good customer relations
probably not worth the effort but seek legal advice as to where you stand and get the shop to do the right thing
Of course you could always go to the social media and state the facts about the service from radio shack
Did you have red antifreeze prior to the flushing? Ford engines are generally aluminium and should be using blue antifreeze which is suitable for aluminium engine blocks! I think the antifreeze is reacting to the aluminium.....re flush and use blue!
1.Try to understand,without waranty not able to service your laptop without charge.
2.I thing you are not statisfing with acer service
3.In this scenario you go to consumer court with strong proof.(that means how many days of your laptop stay in service center only like that)
YOU MORE LIKELY HAVE TO REMOVE RADIO TO GET TO THE BULBS.I WOULD LET THE DEALERSHIP FIX WHEN YOU REMOVE RADIO BY IT BEING PART OF THE ANTI THEFT DETERRENT SYSTEM YOUR CAR WILL GO IN THEFT MODE KEEP CAR FROM STARTING.AND THE AIR BAG IN DASH.THIS IS DANGEROUS JOB TO FIX YOURSELF.
If the battery is not recharging while the car is running, bad connection between alternator and battery. If it is dying while sitting, but charging while running, something is draining it. What? Who knows. It could be anything from a clock on the radio to an engine fan that doesn't stop. Look for anything electrical that is on when the car isn't. ANYTHING. Even the smallest light can pull more juice than you'd expect. Good luck.
Your hard drive (hdd) has crashed/failed and will need to be replaced. There won't be anything you can do this weekend, but on Monday when you call Acer support, tell them you took it to a local tech and he/she checked the hdd and it tested bad, and ask if they can send you a replacement under the warranty if covered. By telling them you had it checked by a professional, it will most likely save you the time of having to send it to Acer so they can take a couple of weeks to tell you the same thing, then send it back with a new hard drive.
since that it crashed, it is more practical that you reformat it, rather than buying new one. it is the system crashed not the whole hard disk and there is a great chance of reviving it , you have the recovery disk with you, then better use it than buying.
