If your Bose 2020 radio is not connecting to your 2016 multi-CD changer and is not recognizing discs 2, 3, or 4, there are a few things you can try to troubleshoot the issue:
1. Check the connections: Make sure that the multi-CD changer is properly connected to the Bose 2020 radio. Check the connections for any loose or disconnected cables.
2. Check the disc format: Make sure that the discs you are trying to play are in a format that is compatible with the CD changer. Some CD changers may not be able to read certain formats or may have trouble reading scratched or damaged discs.
3. Clean the discs: Try cleaning the discs to remove any dust, dirt, or fingerprints. Use a soft, lint-free cloth and wipe from the center of the disc to the outer edge.
4. Clean the CD changer: Dust and debris can build up inside the CD changer, causing it to have trouble reading discs. Try using a CD cleaning disc or a can of compressed air to remove any dust or debris that may be inside the CD changer.
5. Reset the system: Try resetting the Bose 2020 radio and the CD changer. Unplug the power cords from both devices, wait a few minutes, and then plug them back in.
If none of these solutions work, there may be a problem with the CD changer or the radio. You may need to contact Bose customer support for further assistance or take the devices to a qualified technician for repair.
Had the same problem!! Found the solution here under "Wont Play" question. Push that cd chngr magazine (holder) all the way into the unit and tap with a blunt object( Dont tap too hard,it's plastic!!) screw driver worked for me! Push the eject button and you'll hear the unit working! Pop it in and out and it seemed to unfreeze whatever was frozen!! It finally loaded a cd and started playing again. I checked all 6 and they were okay!!
my onkyo 6 disc changer was doing the same thing was doing the same thing. i opened it up and noticed the cds weren't quite stopping at the right spot. so i loosened the screw right in the middle of the disc tray. now operates perfectly now. i think maybe with age, the belt tension got a little lighter ant loosening the screw compensated for it.
where is the lens
but if my cd changer is not picking up the dics that wont work
