Turn the knob because that's when gas will be coming out but of course you cant see it. Then put a sparkler, lighter, or match right above or near the burner. That should keep it going for now until it gets fixed.
Check if the timer is set? If that is okay, a failed element is the most likely cause. Disconnect the leads and check continuity with a test meter.
Belling Oven is Not Heating Up
You can test whether your Belling oven is heating up correctly by turning the oven on, setting the temperature and letting it sit for five minutes. If the oven cavity is not hot when you open the door, it is likely that your oven element is broken.
Hi, If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
If your electric oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Hi, If your electric oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
