Yellow jet appears to ne blocked. Put in a new cartridge but this still hasn't cured it. Tried cleaning routine 3 times but it doesn't seem to help
Please state the model
of your printer.
Vertical lines appears
on prints because the nozzles on your print head are blocked, it doesn't means
all nozzles but some of your nozzles are blocked. A print head of an inkjet
consists of many tiny little pores or nozzles, through which jets of inks are sprayed
on the photo paper to create an image, if some of this tiny pores are blocked
print outs deteriorates, so cleaning the print head is an option if your
printer has print head inside the printer you can first clean it through
the head cleaning option present in the maintainence tab of your printer
software, for printers that have print head on the cartridges, you can add a
few drops of isopropryl alcohol on the print head and leave it for a
minute and put it back on the printer and run the head cleaning utility of your
printer software.
Hope this helps you.
