there is a seprsate actuator for each door/hatch. so it is commen on those for more then one to go bad at about the same time. just look and see if you can see the lock move slightly while tryinng to work it. if so then that is what you need.
is the only thing not working the cigarette lighter? the fuse that operates it is usually the accessories fuse, it normally operates the interior light as well, which fuse box have you checked,there is most likely one under the bonnet & there also may be one under the dash as well, it might well be that the cigarette lighter element is the problem,try another lighter....hope this helps....cheers
there should be a radio code, like a serial number for your xm radio, maybe in your owner's manual. all you do is call xm with this code and have it activated.
1st you will need to contact Infiniti, so they can quote you the option which is $700.00 something dollars when i checked. Just because its equipped there are still things that need to be added in order to make it function. As per the mechanic. Rip off.
