SOURCE: Whirlpool ADP 5500 dishwasher stops - light flashes 7 times.
It's a heating issue either a bad heater or bad sensor.
SOURCE: problem with whirlpool dishwasher ADG957
Continuous flash with no pause is a Faulty NTC (temperature sensor)
Or according to whirlpool it might be that your keys are syticking.
SOURCE: hoover dt999
E4 Error on other machines (eg. Baumatic) means that the bottom catch tray (condensate trap) below the machine has too much water in it. This condensate is supposed to evaporate away, but too much will mean it builds up over a period of time. There is a float that trips a microswitch in my Baumatic which detects this, it only needs 2 - 3mm of water before the microswitch is activated.
If this is the problem with your machine (try it annd see), there are several solutions posted in forums - best seems to be to remove plastic access hole caps from base and mop out the tray with sponge. TURN OFF AT MAINS BEFORE POKING AROUND INSIDE THE BASE. May have to repeat at regular intervals to.
What causes it ? - I think it is excess condensate from steam inside the wash cabinet, follow the manufacturers advice to open the door as soon as the wash cycle has ended to release as much steam as possible to stop it condensing inside the machine.
Peramnent solution ? - I don't think possible - My guess is it's just a bad design.
Dave
SOURCE: i have a cda mx194
MX194 Dishwasher.
Switch off and unplug before doing anything. .
First three lights are flashing on top and it will not stop making stupid noises.
Remove plastic panels at front of machine under door, see if there is water inside.
If there is ... something is leaking. If it is a slow leak - solution is to dry up excess water in tray with paper towels or whatever comes to hand. You will need to find the leak somehow - salt container is usual suspect.
There is a microswitch attached to a float on the left hand side inside a white plastic cover. Water at the base of this activates the switch and disables machine. Mine has not leaked since trying this fix and machine is running well 2 months down the line. Better 10 minutes with paper towels than 2 hours of expensive plumbers.
SOURCE: GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
